Perchè l'audio è penoso?
Re: Perchè l'audio è penoso?
che non centra una mazza.
Vediamo:
cat /etc/asound.state
Messaggio da Zievatron »
root[unknow]# cat /etc/asound.state
state.Intel {
	control.1 {
		iface MIXER
		name 'Speaker Playback Volume'
		value.0 64
		value.1 64
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 64'
			dbmin -4800
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.2 {
		iface MIXER
		name 'Speaker Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.3 {
		iface MIXER
		name 'Front Mic Jack Mode'
		value 'Mic In'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 'Mic In'
			item.1 'Line In'
	control.4 {
		iface MIXER
		name 'Dock Mic Jack Mode'
		value 'Mic In'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 'Mic In'
			item.1 'Line In'
	control.5 {
		iface MIXER
		name 'Headphone Playback Volume'
		value.0 48
		value.1 48
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 64'
			dbmin -4800
			dbmax 0
			dbvalue.0 -1200
			dbvalue.1 -1200
	control.6 {
		iface MIXER
		name 'Headphone Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.7 {
		iface MIXER
		name 'Capture Volume'
		value.0 8
		value.1 8
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 15'
			dbmin 0
			dbmax 2250
			dbvalue.0 1200
			dbvalue.1 1200
	control.8 {
		iface MIXER
		name 'Capture Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.9 {
		iface MIXER
		name 'Internal Mic Capture Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.10 {
		iface MIXER
		name 'Mux Capture Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.11 {
		iface MIXER
		name 'Bass Speaker Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.12 {
		iface MIXER
		name 'IEC958 Playback Source'
		value 'Digital Playback'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 'Digital Playback'
			item.1 'Analog Mux 1'
			item.2 'Analog Mux 2'
	control.13 {
		iface MIXER
		name 'IEC958 Playback Con Mask'
		value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.14 {
		iface MIXER
		name 'IEC958 Playback Pro Mask'
		value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.15 {
		iface MIXER
		name 'IEC958 Playback Default'
		value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.16 {
		iface MIXER
		name 'IEC958 Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.17 {
		iface MIXER
		name 'IEC958 Default PCM Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.18 {
		iface MIXER
		name 'Master Playback Volume'
		value 48
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 64'
			dbmin -9999999
			dbmax 0
			dbvalue.0 -1200
	control.19 {
		iface MIXER
		name 'Master Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.20 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.21 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.22 {
		iface MIXER
		index 1
		comment {
			access 'read write'
			type IEC958
			count 1
	control.23 {
		iface MIXER
		index 1
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
niente che possa interessarci.
devi provare a modificare i file allora.
EDIT: dai uno sguardo qui http://www.alsa-project.org/main/index.php/Asoundrc
e vedi se c'è qualcosa di utile.
Cosa avrebbe potuto esserci d'interessante?
Non è che potrei scaricare ed installare qualcosa che gestisce meglio l'audio?
Alsamixer dovrebbe già fare questo lavoro egregiamente.
Non ho mai fatto una cosa simile.... ma dopodomani sera avrò un po' di tempo.
saresti in grado di passarmi un pezzo di audio 5.1 che faccio delle prove??? :D
E come si fa? :hmm:
...bella domanda...
dovresti estrarre l'audio (virtualdub?)...e mandarlo...
Oppure potrebbe dirti da dove lo prende e vedere se riesci a trovarlo anche tu ;)
dino ha scritto:Oppure potrebbe dirti da dove lo prende e vedere se riesci a trovarlo anche tu ;)
anche.
più che altro dovrò fare delle prove e metterlo nei tips! ;)
Conoscè non hai un film in dvd ??? :)
