download vmware server su debian essenzial
Re: download vmware server su debian essenzial
Il link al pacchetto è.....?
What is the location of the directory of C header files that match your running
kernel? [/lib/modules/2.6.3211/build/include]
Extracting the sources of the vmmon module.
Building the vmmon module.
Using 2.6.x kernel build system.
make: Entering directory `/tmp/vmware-config4/vmmon-only'
make -C /lib/modules/2.6.3211/build/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. modules
make[1]: Entering directory `/usr/src/linux-source-2.6.32'
CC [M] /tmp/vmware-config4/vmmon-only/linux/driver.o
In file included from /tmp/vmware-config4/vmmon-only/linux/driver.c:31:
/tmp/vmware-config4/vmmon-only/./include/compat_wait.h:78: error: conflicting types for 'poll_initwait'
include/linux/poll.h:70: note: previous declaration of 'poll_initwait' was here
In file included from /tmp/vmware-config4/vmmon-only/./include/vmware.h:38,
from /tmp/vmware-config4/vmmon-only/linux/driver.c:99:
/tmp/vmware-config4/vmmon-only/./include/vm_basic_types.h:108:7: warning: "__FreeBSD__" is not defined
In file included from /tmp/vmware-config4/vmmon-only/./common/vmx86.h:32,
from /tmp/vmware-config4/vmmon-only/linux/driver.h:29,
from /tmp/vmware-config4/vmmon-only/linux/driver.c:101:
/tmp/vmware-config4/vmmon-only/./include/x86msr.h:164:1: warning: "MSR_THERM2_CTL" redefined
In file included from /usr/src/linux-source-2.6.32/arch/x86/include/asm/msr.h:4,
from /usr/src/linux-source-2.6.32/arch/x86/include/asm/processor.h:21,
from include/linux/prefetch.h:14,
from include/linux/list.h:6,
from include/linux/module.h:9,
from /tmp/vmware-config4/vmmon-only/./include/compat_module.h:27,
from /tmp/vmware-config4/vmmon-only/linux/driver.c:26:
/usr/src/linux-source-2.6.32/arch/x86/include/asm/msr-index.h:234:1: warning: this is the location of the previous definition
In file included from /tmp/vmware-config4/vmmon-only/./include/vcpuset.h:103,
from /tmp/vmware-config4/vmmon-only/./include/modulecall.h:37,
from /tmp/vmware-config4/vmmon-only/./common/vmx86.h:33,
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:329:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:333:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:401:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:407:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:460:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:506:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:551:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:595:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:640:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:684:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:729:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:773:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:775:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:816:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:860:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:862:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:903:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:945:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:947:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:986:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:1028:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:1030:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:1069:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:1223:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:1227:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:1313:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:1536:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:1663:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_atomic.h:1796:7: warning: "_MSC_VER" is not defined
In file included from /tmp/vmware-config4/vmmon-only/./include/vm_asm_x86_64.h:39,
from /tmp/vmware-config4/vmmon-only/./include/vm_asm.h:41,
from /tmp/vmware-config4/vmmon-only/linux/driver.c:103:
/tmp/vmware-config4/vmmon-only/./include/vm_asm_x86.h:486:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_asm_x86.h:779:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_asm_x86.h:820:7: warning: "_MSC_VER" is not defined
/tmp/vmware-config4/vmmon-only/./include/vm_asm_x86.h:922:7: warning: "_MSC_VER" is not defined
In file included from /tmp/vmware-config4/vmmon-only/./include/vm_asm.h:41,
/tmp/vmware-config4/vmmon-only/./include/vm_asm_x86_64.h:56:7: warning: "_MSC_VER" is not defined
In file included from /tmp/vmware-config4/vmmon-only/linux/driver.c:119:
/tmp/vmware-config4/vmmon-only/./common/hostif.h:53:7: warning: "WINNT_DDK" is not defined
/tmp/vmware-config4/vmmon-only/linux/driver.c: In function 'LinuxDriverSyncCallOnEachCPU':
/tmp/vmware-config4/vmmon-only/linux/driver.c:1423: error: too many arguments to function 'smp_call_function'
/tmp/vmware-config4/vmmon-only/linux/driver.c: In function 'LinuxDriver_Ioctl':
/tmp/vmware-config4/vmmon-only/linux/driver.c:1987: error: 'struct task_struct' has no member named 'euid'
/tmp/vmware-config4/vmmon-only/linux/driver.c:1987: error: 'struct task_struct' has no member named 'uid'
/tmp/vmware-config4/vmmon-only/linux/driver.c:1988: error: 'struct task_struct' has no member named 'fsuid'
/tmp/vmware-config4/vmmon-only/linux/driver.c:1988: error: 'struct task_struct' has no member named 'uid'
/tmp/vmware-config4/vmmon-only/linux/driver.c:1989: error: 'struct task_struct' has no member named 'egid'
/tmp/vmware-config4/vmmon-only/linux/driver.c:1989: error: 'struct task_struct' has no member named 'gid'
/tmp/vmware-config4/vmmon-only/linux/driver.c:1990: error: 'struct task_struct' has no member named 'fsgid'
/tmp/vmware-config4/vmmon-only/linux/driver.c:1990: error: 'struct task_struct' has no member named 'gid'
/tmp/vmware-config4/vmmon-only/linux/driver.c:2007: error: too many arguments to function 'smp_call_function'
make[2]: *** [/tmp/vmware-config4/vmmon-only/linux/driver.o] Error 1
make[1]: *** [_module_/tmp/vmware-config4/vmmon-only] Error 2
make[1]: Leaving directory `/usr/src/linux-source-2.6.32'
make: *** [vmmon.ko] Error 2
make: Leaving directory `/tmp/vmware-config4/vmmon-only'
Unable to build the vmmon module.
For more information on how to troubleshoot module-related problems, please
visit our Web site at "http://www.vmware.com/go/unsup-linux-products" and
"http://www.vmware.com/go/unsup-linux-tools".
Execution aborted.
edit2: ho c'erano da aplicare le patch qui c'è una guida link
mi da questo errore
edit il link dovrebbe essere questo
https://dlm2.vmware.com/akdlm/software/server/VMware-server-2.0.2-203138.x86_64.tar.gz?HashKey=cce43be148a34c1a2fdbf7f6194c5527&lang=en&AuthKey=1362181682_5dd5dda861dae6adde1c704d9a1b2925&dlmauthparam=1362209583_c7a5eefaf6703275713a083f31b0689a&fileExt=.gz
Ultima modifica di mafferri il lunedì 11 marzo 2013, 22:32, modificato 1 volta in totale.
uname -r
per il link... ora non sono su linux per provare!
ti farò sapere.
ti farò sapere.
editato sopra , ma tu rispondeviconoscenza ha scritto:uname -r
ti farò sapere.
ok grazie
bravo che posti le guide!
dai un feedback sul risultato.
Ahimè il lavoro non mi permette di dare risposte celeri e certe qui sul forum!
faccio del mio meglio...
non ti preoccupare, alla fine ci voleva la patch per i kernel uguali o superiori a 2.6.30, poi ci sono stati dei problemi col nome del kernel gcc nulla che nn si risolve xD
ora cerco le istruzioni per configurarlo da riga di comando perchè mi son dimenticato di mappare la porta hhtps
Perdona l'intromissione, ma quante macchine virtuali devi tirare su? Potrebbe bastarti Virtualbox con il quale puoi in seguito "manovrare" le vm a riga di comando. Te lo chiedo perchè è nei repository debian e magari ti risparmi l'ambardam.
Ops scusa non avevo capito che in seguito sei riuscito ad installarlo. Buona virtualizzazione allora
grazie, ho deciso vmware server perchè ha il pannello di controllo tramite https ,percui se crasha qualcosa anche mio fratello può riavviare la macchina con sevenJena Plisskin ha scritto:Perdona l'intromissione, ma quante macchine virtuali devi tirare su? Potrebbe bastarti Virtualbox con il quale puoi in seguito "manovrare" le vm a riga di comando. Te lo chiedo perchè è nei repository debian e magari ti risparmi l'ambardam.
Io vorrei fare , 3 macchine virtuali , una con freenas per la condivisione degli hd , una con seven per il desktop remoto di mio fratello , e una distro con gnome o kde , poi deciderò che utilizzerò io.
