conoscenza ha scritto:Allora monta tutto e fai:
posta i risultati.... che si continua!
Se non ci sono fai:...
Altrochè se ci sono i risultati!
Un bel malloppo direi.
Eccoli:
darkstar / # emerge portage
* IMPORTANT: 1 news items need reading for repository 'gentoo'.
* Use eselect news to read news items.
>>> Verifying ebuild manifests
>>> Emerging (1 of 1) sys-apps/portage-2.1.10.44
>>> Downloading 'http://distfiles.gentoo.org/distfiles/portage-2.1.10.44.tar.bz2'
--2012-03-02 00:34:57-- http://distfiles.gentoo.org/distfiles/portage-2.1.10.44.tar.bz2
Risoluzione di distfiles.gentoo.org... 64.50.233.100, 64.50.236.52, 137.226.34.42, ...
Connessione a distfiles.gentoo.org|64.50.233.100|:80... connesso.
HTTP richiesta inviata, in attesa di risposta... 200 OK
Lunghezza: 781681 (763K) [application/x-bzip2]
Salvataggio in: "/usr/portage/distfiles/portage-2.1.10.44.tar.bz2"
100%[======================================>] 781.681 403K/s in 1,9s
2012-03-02 00:35:00 (403 KB/s) - "/usr/portage/distfiles/portage-2.1.10.44.tar.bz2" salvato [781681/781681]
* portage-2.1.10.44.tar.bz2 RMD160 SHA1 SHA256 size ;-) ... [ ok ]
>>> Unpacking source...
>>> Unpacking portage-2.1.10.44.tar.bz2 to /var/tmp/portage/sys-apps/portage-2.1.10.44/work
>>> Source unpacked in /var/tmp/portage/sys-apps/portage-2.1.10.44/work
>>> Preparing source in /var/tmp/portage/sys-apps/portage-2.1.10.44/work/portage-2.1.10.44 ...
* Setting portage.VERSION to 2.1.10.44 ...
>>> Source prepared.
>>> Configuring source in /var/tmp/portage/sys-apps/portage-2.1.10.44/work/portage-2.1.10.44 ...
>>> Source configured.
>>> Compiling source in /var/tmp/portage/sys-apps/portage-2.1.10.44/work/portage-2.1.10.44 ...
>>> Source compiled.
>>> Test phase [not enabled]: sys-apps/portage-2.1.10.44
>>> Install portage-2.1.10.44 into /var/tmp/portage/sys-apps/portage-2.1.10.44/image/ category sys-apps
patching file make.conf
Hunk #1 succeeded at 22 (offset -1 lines).
Hunk #2 succeeded at 43 with fuzz 2 (offset 5 lines).
Hunk #3 succeeded at 105 (offset 14 lines).
>>> Completed installing portage-2.1.10.44 into /var/tmp/portage/sys-apps/portage-2.1.10.44/image/
strip: x86_64-pc-linux-gnu-strip --strip-unneeded -R .comment -R .GCC.command.line
ecompressdir: bzip2 -9 /usr/share/man
>>> Installing (1 of 1) sys-apps/portage-2.1.10.44
* Running preinst sanity tests...
testBashSyntax (portage.tests.lint.test_bash_syntax.BashSyntaxTestCase) ... ok
testCompileModules (portage.tests.lint.test_compile_modules.CompileModulesTestCase) ... ok
testImportModules (portage.tests.lint.test_import_modules.ImportModulesTestCase) ... ok
Ran 3 tests in 3.836s
OK
* Compilation and optimization of Python modules placed outside of site-packages directories for CPython 2.7 ... [ ok ]
>>> Recording sys-apps/portage in "world" favorites file...
>>> Auto-cleaning packages...
>>> No outdated packages were found on your system.
* GNU info directory index is up-to-date.
darkstar / # emerge syslog-ng
[nomerge ] net-print/foomatic-filters-4.0.9 USE="cups dbus"
[nomerge ] app-text/ghostscript-gpl-9.04-r4 USE="X cups dbus djvu gtk jpeg2k static-libs -bindist -idn" LINGUAS="-ja -ko -zh_CN -zh_TW"
[nomerge ] x11-libs/gtk+-2.24.8-r1 USE="cups introspection (-aqua) -debug -doc -examples -test -vim-syntax -xinerama"
[nomerge ] net-print/cups-1.4.8-r1 USE="X acl dbus filters gnutls java jpeg ldap pam perl png python ssl static-libs threads tiff -debug -kerberos -php -slp -xinetd" LINGUAS="-da -de -es -eu -fi -fr -id -it -ja -ko -nl -no -pl -pt -pt_BR -ru -sv -zh -zh_TW"
[nomerge ] app-text/poppler-0.16.7 USE="cairo curl cxx introspection jpeg jpeg2k lcms png qt4 utils xpdf-headers -cjk -debug -doc -exceptions"
[nomerge ] media-libs/openjpeg-1.4-r1 USE="-doc -test"
[nomerge ] dev-util/cmake-2.8.6-r4 USE="ncurses qt4 -emacs -test -vim-syntax"
[nomerge ] x11-libs/qt-gui-4.7.4-r1 USE="accessibility cups dbus exceptions glib mng nas pch qt3support tiff (-aqua) -debug -egl -gtkstyle -nis -private-headers -raster -trace -xinerama"
[ebuild N ] x11-libs/qt-qt3support-4.7.4 USE="accessibility exceptions pch (-aqua) -debug -kde -phonon" 215,223 kB
[ebuild N ] x11-libs/qt-sql-4.7.4 USE="exceptions iconv mysql pch qt3support sqlite (-aqua) -debug -firebird -freetds -odbc -postgres" 0 kB
[nomerge ] dev-perl/DBD-mysql-4.01.7
[nomerge ] virtual/mysql-5.1 USE="embedded -minimal -static"
[ebuild N ] dev-db/mysql-5.1.61 USE="berkdb community embedded perl ssl -big-tables -cluster -debug -extraengine -latin1 -max-idx-128 -minimal -pbxt -profiling (-selinux) -static -test -xtradb" 25,628 kB
[ebuild N ] dev-perl/DBD-mysql-4.01.7 130 kB
[nomerge ] app-admin/syslog-ng-3.2.5 USE="ipv6 pcre sql ssl tcpd -caps -hardened (-selinux) -spoof-source"
[nomerge ] dev-db/libdbi-0.8.3 USE="-doc"
[ebuild N ] dev-db/libdbi-drivers-0.8.3 USE="mysql sqlite -bindist -doc (-firebird) -oci8 -postgres -sqlite3" 1,499 kB
[ebuild N ] virtual/mysql-5.1 USE="embedded -minimal -static" 0 kB
[nomerge ] x11-libs/cairo-1.10.2-r1 USE="X glib opengl qt4 static-libs svg xcb (-aqua) -debug -directfb -doc (-drm) (-gallium) (-openvg)"
[nomerge ] dev-java/java-config-2.1.11-r3
[ebuild N ] virtual/jre-1.6.0 0 kB
[ebuild N ] virtual/jdk-1.6.0 0 kB
[ebuild N ] dev-java/icedtea-bin-6.1.11.1 USE="X alsa cups -cjk -doc -examples -nsplugin -source" 34,387 kB
[nomerge ] dev-java/icedtea-bin-6.1.11.1 USE="X alsa cups -cjk -doc -examples -nsplugin -source"
[nomerge ] dev-libs/gobject-introspection-1.30.0-r2 USE="-doc -test"
[nomerge ] x11-libs/xcb-util-0.3.8 USE="static-libs -doc -test"
[ebuild N ] x11-libs/xcb-util-wm-0.3.8 USE="static-libs -doc -test" 299 kB
[ebuild N ] x11-libs/xcb-util-image-0.3.8 USE="static-libs -doc -test" 283 kB
[ebuild N ] x11-libs/xcb-util-renderutil-0.3.8 USE="static-libs -doc -test" 252 kB
[ebuild N ] x11-libs/xcb-util-keysyms-0.3.8 USE="static-libs -doc -test" 247 kB
[ebuild N ] net-print/foomatic-filters-4.0.9 USE="cups dbus" 249 kB
[ebuild N ] app-text/poppler-0.16.7 USE="cairo curl cxx introspection jpeg jpeg2k lcms png qt4 utils xpdf-headers -cjk -debug -doc -exceptions" 1,907 kB
[ebuild N ] app-text/ghostscript-gpl-9.04-r4 USE="X cups dbus djvu gtk jpeg2k static-libs -bindist -idn" LINGUAS="-ja -ko -zh_CN -zh_TW" 29,381 kB
[ebuild N ] x11-libs/gtk+-2.24.8-r1 USE="cups introspection (-aqua) -debug -doc -examples -test -vim-syntax -xinerama" 12,513 kB
[ebuild N ] x11-libs/pango-1.28.4 USE="X introspection -debug -doc -test" 1,469 kB
[ebuild N ] x11-libs/cairo-1.10.2-r1 USE="X glib opengl qt4 static-libs svg xcb (-aqua) -debug -directfb -doc (-drm) (-gallium) (-openvg)" 23,007 kB
[ebuild N ] x11-libs/xcb-util-0.3.8 USE="static-libs -doc -test" 261 kB
[ebuild N ] net-print/cups-1.4.8-r1 USE="X acl dbus filters gnutls java jpeg ldap pam perl png python ssl static-libs threads tiff -debug -kerberos -php -slp -xinetd" LINGUAS="-da -de -es -eu -fi -fr -id -it -ja -ko -nl -no -pl -pt -pt_BR -ru -sv -zh -zh_TW" 4,441 kB
[ebuild N ] media-libs/openjpeg-1.4-r1 USE="-doc -test" 2,311 kB
[ebuild N ] dev-util/cmake-2.8.6-r4 USE="ncurses qt4 -emacs -test -vim-syntax" 5,454 kB
[ebuild N ] x11-libs/qt-gui-4.7.4-r1 USE="accessibility cups dbus exceptions glib mng nas pch qt3support tiff (-aqua) -debug -egl -gtkstyle -nis -private-headers -raster -trace -xinerama" 0 kB
[nomerge ] x11-libs/libXft-2.2.0 USE="static-libs"
[nomerge ] virtual/ttf-fonts-1
[nomerge ] media-fonts/dejavu-2.33 USE="X -fontforge"
[nomerge ] media-libs/fontconfig-2.8.0-r1 USE="-doc"
[ebuild N ] app-admin/eselect-fontconfig-1.1 2 kB
[nomerge ] dev-libs/atk-1.32.0-r1 USE="introspection nls -doc"
[nomerge ] dev-lang/python-2.7.2-r3 USE="gdbm* ipv6* ncurses* readline* sqlite* ssl* threads* tk* (wide-unicode) xml* -berkdb -build* -doc -examples -wininst"
[ebuild N ] dev-tcltk/blt-2.4z-r10 USE="X jpeg static-libs" 2,272 kB
[ebuild N ] media-fonts/urw-fonts-2.4.9 USE="X" 3,124 kB
[nomerge ] media-libs/lcms-1.19 USE="jpeg python static-libs tiff -zlib"
[ebuild N ] dev-lang/tk-8.5.9-r1 USE="threads truetype (-aqua) -debug -xscreensaver" 3,736 kB
[ebuild N ] x11-libs/libXft-2.2.0 USE="static-libs" 284 kB
[ebuild N ] virtual/ttf-fonts-1 0 kB
[ebuild N ] media-fonts/dejavu-2.33 USE="X -fontforge" 4,767 kB
[ebuild N ] media-libs/fontconfig-2.8.0-r1 USE="-doc" 1,513 kB
[ebuild N ] x11-libs/gdk-pixbuf-2.24.0-r1 USE="X introspection jpeg jpeg2k tiff -debug -doc -test" 1,149 kB
[ebuild N ] media-libs/jasper-1.900.1-r4 USE="jpeg opengl static-libs" 1,392 kB
[ebuild N ] media-libs/freeglut-2.8.0 USE="static-libs -debug" 957 kB
[ebuild N ] virtual/glu-7.0 0 kB
[ebuild N ] virtual/opengl-7.0 0 kB
[ebuild N ] media-libs/mesa-7.11.2 USE="classic egl gallium llvm nptl shared-glapi -bindist -debug -gbm -gles -motif -openvg -osmesa -pax_kernel -pic (-selinux) -shared-dricore" VIDEO_CARDS="radeon -intel -mach64 -mga -nouveau -r128 -savage -sis -tdfx -via -vmware" 6,115 kB
[ebuild U ] dev-libs/libxml2-2.7.8-r5 [2.7.8-r4] USE="icu* ipv6 python* readline static-libs* -debug -doc -examples -test" 4,768 kB
[ebuild N ] x11-libs/libxcb-1.7 USE="static-libs -doc (-selinux)" 312 kB
[ebuild R ] dev-lang/python-2.7.2-r3 USE="gdbm* ipv6* ncurses* readline* sqlite* ssl* threads* tk* (wide-unicode) xml* -berkdb -build* -doc -examples -wininst" 11,494 kB
[ebuild N ] x11-libs/libXtst-1.2.0 USE="static-libs -doc" 276 kB
[ebuild N ] media-libs/giflib-4.1.6-r2 USE="X static-libs -rle" 495 kB
[ebuild N ] media-libs/nas-1.9.2 USE="-doc" 1,450 kB
[ebuild N ] x11-libs/libXaw-1.0.9 USE="static-libs -doc" 636 kB
[ebuild N ] x11-libs/libXpm-3.5.9 USE="static-libs" 375 kB
[ebuild N ] x11-libs/libXres-1.0.5 USE="static-libs" 235 kB
[ebuild N ] x11-libs/libXTrap-1.0.0 USE="-debug" 215 kB
[ebuild N ] x11-libs/libXp-1.0.1 USE="static-libs" 294 kB
[ebuild N ] x11-misc/xdg-utils-1.1.0_rc1_p20111003 USE="perl -doc" 1,141 kB
[ebuild N ] x11-apps/xset-1.2.2 127 kB
[ebuild N ] x11-apps/xprop-1.2.1 131 kB
[ebuild N ] x11-libs/libXcomposite-0.4.3-r1 USE="static-libs -doc" 241 kB
[nomerge ] x11-libs/qt-qt3support-4.7.4 USE="accessibility exceptions pch (-aqua) -debug -kde -phonon"
[ebuild N ] x11-libs/libXfont-1.4.4 USE="ipv6 static-libs -doc" 430 kB
[ebuild N ] x11-libs/qt-dbus-4.7.4 USE="exceptions pch (-aqua) -debug" 0 kB
[nomerge ] virtual/glu-7.0
[nomerge ] media-libs/mesa-7.11.2 USE="classic egl gallium llvm nptl shared-glapi -bindist -debug -gbm -gles -motif -openvg -osmesa -pax_kernel -pic (-selinux) -shared-dricore" VIDEO_CARDS="radeon -intel -mach64 -mga -nouveau -r128 -savage -sis -tdfx -via -vmware"
[ebuild N ] x11-libs/libXxf86vm-1.1.1 USE="static-libs" 247 kB
[ebuild N ] x11-libs/libXdamage-1.1.3 USE="static-libs" 244 kB
[ebuild N ] media-fonts/encodings-1.0.4 650 kB
[ebuild N ] x11-apps/mkfontdir-1.0.6 96 kB
[ebuild N ] x11-apps/mkfontscale-1.0.9-r1 124 kB
[nomerge ] x11-libs/qt-core-4.7.4-r1 USE="exceptions glib iconv jit optimized-qmake pch qt3support ssl (-aqua) -debug -private-headers"
[ebuild N ] x11-libs/libXcursor-1.1.12 USE="static-libs" 291 kB
[nomerge ] x11-libs/libXaw-1.0.9 USE="static-libs -doc"
[ebuild N ] x11-libs/libXmu-1.1.0 USE="ipv6 static-libs -doc" 353 kB
[ebuild N ] x11-libs/libXrandr-1.3.2 USE="static-libs" 268 kB
[ebuild N ] x11-libs/libXfixes-5.0 USE="static-libs" 248 kB
[nomerge ] x11-libs/qt-dbus-4.7.4 USE="exceptions pch (-aqua) -debug"
[ebuild N ] sys-apps/dbus-1.4.16 USE="X static-libs -debug -doc (-selinux) -test" 1,846 kB
[nomerge ] x11-libs/libXrandr-1.3.2 USE="static-libs"
[ebuild N ] x11-libs/libXrender-0.9.6 USE="static-libs" 253 kB
[ebuild N ] x11-libs/libXi-1.4.3-r1 USE="static-libs -doc" 413 kB
[ebuild N ] x11-libs/libXt-1.1.1 USE="static-libs" 699 kB
[ebuild N ] media-libs/freetype-2.4.8 USE="X bzip2 static-libs -auto-hinter -bindist -debug -doc -fontforge -utils" 1,458 kB
[ebuild N ] x11-libs/libXext-1.3.0 USE="static-libs -doc" 334 kB
[ebuild N ] x11-libs/libX11-1.4.4 USE="ipv6 static-libs -doc -test" 2,269 kB
Total: 71 packages (1 upgrade, 69 new, 1 reinstall), Size of downloads: 416,634 kB
* Error: circular dependencies:
(dev-lang/python-2.7.2-r3::gentoo, ebuild scheduled for merge) depends on
(dev-lang/tk-8.5.9-r1::gentoo, ebuild scheduled for merge) (buildtime)
(x11-libs/libX11-1.4.4::gentoo, ebuild scheduled for merge) (buildtime)
(x11-libs/libxcb-1.7::gentoo, ebuild scheduled for merge) (buildtime)
(dev-lang/python-2.7.2-r3::gentoo, ebuild scheduled for merge) (buildtime)
It might be possible to break this cycle
by applying any of the following changes:
- dev-lang/python-2.7.2-r3 (Change USE: -tk)
- dev-lang/python-2.7.2-r3 (Change USE: +build)
Note that this change can be reverted, once the package has been installed.
Note that the dependency graph contains a lot of cycles.
Several changes might be required to resolve all cycles.
Temporarily changing some use flag for all packages might be the better option.
!!! Multiple package instances within a single package slot have been pulled
!!! into the dependency graph, resulting in a slot conflict:
dev-libs/libxml2:2
(dev-libs/libxml2-2.7.8-r4::gentoo, installed) pulled in by
(no parents that aren't satisfied by other packages in this slot)
(dev-libs/libxml2-2.7.8-r5::gentoo, ebuild scheduled for merge) pulled in by
dev-libs/libxml2[python] required by (media-libs/mesa-7.11.2::gentoo, ebuild scheduled for merge)
!!! Enabling --newuse and --update might solve this conflict.
!!! If not, it might help emerge to give a more specific suggestion.
darkstar / #
