quello che ti ho fatto fare serviva solo per attivare il log del boot.
hai riavviato Gentoo?
se si,... e non si è avviato,... postami:
cat /var/log/rc.log
..ovviamente di gentoo chrootato!
conoscenza ha scritto:quello che ti ho fatto fare serviva solo per attivare il log del boot.
cat /var/log/rc.log
Ma sì che l'ho avviato.
Ha prodotto ancora il kernel panic e, come ti ho mostrato prima con la ricerca dei .log, non è comparso nessun /var/log/rc.log.
darkstar / # cat /etc/rc.conf
# Global OpenRC configuration settings
# Set rc_interactive to "YES" and you'll be able to press the I key during
# boot so you can choose to start specific services. Set to "NO" to disable
# this feature.
#rc_interactive="YES"
# If we need to drop to a shell, you can specify it here.
# If not specified we use $SHELL, otherwise the one specified in /etc/passwd,
# otherwise /bin/sh
# Linux users could specify /sbin/sulogin
rc_shell=/sbin/sulogin
# Do we allow any started service in the runlevel to satisfy the dependency
# or do we want all of them regardless of state? For example, if net.eth0
# and net.eth1 are in the default runlevel then with rc_depend_strict="NO"
# both will be started, but services that depend on 'net' will work if either
# one comes up. With rc_depend_strict="YES" we would require them both to
# come up.
#rc_depend_strict="YES"
# rc_hotplug is a list of services that we allow to be hotplugged.
# By default we do not allow hotplugging.
# A hotplugged service is one started by a dynamic dev manager when a matching
# hardware device is found.
# This service is intrinsically included in the boot runlevel.
# To disable services, prefix with a !
# Example - rc_hotplug="net.wlan !net.*"
# This allows net.wlan and any service not matching net.* to be plugged.
# Example - rc_hotplug="*"
# This allows all services to be hotplugged
#rc_hotplug="*"
# rc_logger launches a logging daemon to log the entire rc process to
# /var/log/rc.log
# NOTE: Linux systems require the devfs service to be started before
# logging can take place and as such cannot log the sysinit runlevel.
rc_logger="YES"
# Through rc_log_path you can specify a custom log file.
# The default value is: /var/log/rc.log
rc_log_path="/var/log/rc.log"
# By default we filter the environment for our running scripts. To allow other
# variables through, add them here. Use a * to allow all variables through.
#rc_env_allow="VAR1 VAR2"
# By default we assume that all daemons will start correctly.
# However, some do not - a classic example is that they fork and return 0 AND
# then child barfs on a configuration error. Or the daemon has a bug and the
# child crashes. You can set the number of milliseconds start-stop-daemon
# waits to check that the daemon is still running after starting here.
# The default is 0 - no checking.
#rc_start_wait=100
# rc_nostop is a list of services which will not stop when changing runlevels.
# This still allows the service itself to be stopped when called directly.
#rc_nostop=""
# rc will attempt to start crashed services by default.
# However, it will not stop them by default as that could bring down other
# critical services.
#rc_crashed_stop=NO
#rc_crashed_start=YES
# MISC CONFIGURATION VARIABLES
# There variables are shared between many init scripts
# Set unicode to YES to turn on unicode support for keyboards and screens.
unicode="YES"
# Below is the default list of network fstypes.
# afs cifs coda davfs fuse fuse.sshfs gfs glusterfs lustre ncpfs
# nfs nfs4 ocfs2 shfs smbfs
# If you would like to add to this list, you can do so by adding your
# own fstypes to the following variable.
#extra_net_fs_list=""
# SERVICE CONFIGURATION VARIABLES
# These variables are documented here, but should be configured in
# /etc/conf.d/foo for service foo and NOT enabled here unless you
# really want them to work on a global basis.
# Some daemons are started and stopped via start-stop-daemon.
# We can set some things on a per service basis, like the nicelevel.
#export SSD_NICELEVEL="-19"
# Pass ulimit parameters
#rc_ulimit="-u 30"
# It's possible to define extra dependencies for services like so
#rc_config="/etc/foo"
#rc_need="openvpn"
#rc_use="net.eth0"
#rc_after="clock"
#rc_before="local"
#rc_provide="!net"
# You can also enable the above commands here for each service. Below is an
# example for service foo.
#rc_foo_config="/etc/foo"
#rc_foo_need="openvpn"
#rc_foo_after="clock"
# You can also remove dependencies.
# This is mainly used for saying which servies do NOT provide net.
#rc_net_tap0_provide="!net"
# LINUX SPECIFIC OPTIONS
# This is the subsystem type. Valid options on Linux:
# "" - nothing special
# "lxc" - Linux Containers
# "openvz" - Linux OpenVZ
# "prefix" - Prefix
# "uml" - Usermode Linux
# "vserver" - Linux vserver
# "xen0" - Xen0 Domain
# "xenU" - XenU Domain
# If this is commented out, automatic detection will be attempted.
# Note that autodetection will not work in a prefix environment or in a
# linux container.
# This should be set to the value representing the environment this file is
# PRESENTLY in, not the virtualization the environment is capable of.
#rc_sys=""
# This is the number of tty's used in most of the rc-scripts (like
# consolefont, numlock, etc ...)
rc_tty_number=12
darkstar / # emerge -p sys-fs/devfsd
These are the packages that would be merged, in order:
!!! All ebuilds that could satisfy "sys-fs/devfsd" have been masked.
!!! One of the following masked packages is required to complete your request:
- sys-fs/devfsd-1.3.25-r9::gentoo (masked by: missing keyword)
For more information, see the MASKED PACKAGES section in the emerge
man page or refer to the Gentoo Handbook.
darkstar / # emerge -p sys-fs/udev
[ebuild R ] sys-fs/udev-171-r6
darkstar / # emerge sys-fs/devfsd
!!! All ebuilds that could satisfy "<sys-kernel/linux-headers-2.6.18" have been masked.
- sys-kernel/linux-headers-2.4.36::gentoo (masked by: missing keyword)
- sys-kernel/linux-headers-2.4.33.3::gentoo (masked by: missing keyword)
(dependency required by "sys-fs/devfsd-1.3.25-r9" [ebuild])
(dependency required by "sys-fs/devfsd" [argument])
