>>> Installing (2 of 2) sys-fs/devfsd-1.3.25-r9
* You may wish to read the Gentoo Linux Device Filesystem Guide,
* which can be found online at:
* http://www.gentoo.org/doc/en/devfs-guide.xml
>>> Recording sys-fs/devfsd in "world" favorites file...
* Messages for package sys-kernel/linux-headers-2.4.36:
* Be warned !! >=sys-devel/gcc-4.0.0 isn't supported with linux-2.4!
* Either switch to another gcc-version (via gcc-config) or use a
* newer kernel that supports gcc-4.
* Also be aware that bugreports about gcc-4 not working
* with linux-2.4 based ebuilds will be closed as INVALID!
>>> Auto-cleaning packages...
>>> No outdated packages were found on your system.
* GNU info directory index is up-to-date.
root[grub]# cat grub.cfg
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
load_env
fi
set default="${saved_entry}"
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function load_video {
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
insmod part_msdos
insmod ext2
set root='(hd0,msdos9)'
search --no-floppy --fs-uuid --set=root cf256b0c-9779-4386-b499-9dfd55400ed9
if loadfont /usr/share/grub/unicode.pf2 ; then
set gfxmode=auto
load_video
insmod gfxterm
insmod part_msdos
insmod ext2
set root='(hd0,msdos8)'
search --no-floppy --fs-uuid --set=root 14610283-7603-47e4-bc75-1d43830d1077
set locale_dir=($root)/grub/locale
set lang=it_IT
insmod gettext
fi
terminal_output gfxterm
insmod part_msdos
insmod ext2
insmod jpeg
background_image -m stretch /grub/salix.jpg
set timeout=5
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Salix 13.37.0 GNU/Linux, con Linux 3.3.6' --class salix --class gnu-linux --class gnu --class os {
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
echo 'Caricamento Linux 3.3.6...'
linux /vmlinuz-huge-recent-3.3.6 root=/dev/sda9 ro vt.default_utf8=1 resume=/dev/sda4 quiet vga=791
menuentry 'Salix 13.37.0 GNU/Linux, con Linux 3.3.6 (modalità ripristino)' --class salix --class gnu-linux --class gnu --class os {
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
linux /vmlinuz-huge-recent-3.3.6 root=/dev/sda9 ro single vt.default_utf8=1 resume=/dev/sda4
menuentry 'Salix 13.37.0 GNU/Linux, con Linux 2.6.37.6' --class salix --class gnu-linux --class gnu --class os {
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
echo 'Caricamento Linux 2.6.37.6...'
linux /vmlinuz-huge-2.6.37.6 root=/dev/sda9 ro vt.default_utf8=1 resume=/dev/sda4 quiet vga=791
menuentry 'Salix 13.37.0 GNU/Linux, con Linux 2.6.37.6 (modalità ripristino)' --class salix --class gnu-linux --class gnu --class os {
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
linux /vmlinuz-huge-2.6.37.6 root=/dev/sda9 ro single vt.default_utf8=1 resume=/dev/sda4
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry "Windows Vista (loader) (on /dev/sda1)" --class windows --class os {
insmod part_msdos
insmod ntfs
set root='(hd0,msdos1)'
search --no-floppy --fs-uuid --set=root 9AEC72D6EC72AC5F
chainloader +1
menuentry "Windows Vista (loader) (on /dev/sda2)" --class windows --class os {
insmod part_msdos
insmod ntfs
set root='(hd0,msdos2)'
search --no-floppy --fs-uuid --set=root 04B262BDB262B33A
chainloader +1
menuentry "Gentoo Linux 3.2.12 (on /dev/sda6)" --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
set root='(hd0,msdos6)'
search --no-floppy --fs-uuid --set=root 3f6da8d8-d003-4eb8-b429-cffeff309ba7
linux /boot/kernel-3.2.12-gentoo root=/dev/sda6 ro
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
