Ecco:conoscenza ha scritto:scusa per il tempo atteso, ma sono molto impegnato. (esco di casa alle 6 e torno alle 21)
Mi fai vedere:Codice: Seleziona tutto
eix xfce4
darkstar / # eix xfce4
[I] dev-util/xfce4-dev-tools
Available versions: 4.9.1
Installed versions: 4.9.1(13:08:09 14/03/2012)
Homepage: http://www.xfce.org/ http://foo-projects.org/~benny/projects/xfce4-dev-tools/
Description: A set of scripts and m4/autoconf macros that ease build system maintenance
[I] xfce-base/libxfce4ui
Available versions: 4.8.0 4.8.1 ~4.9.0 {debug glade startup-notification}
Installed versions: 4.8.1(20:46:45 08/03/2012)(startup-notification -debug -glade)
Homepage: http://www.xfce.org/projects/libxfce4
Description: Unified widgets and session management libraries for the Xfce desktop environment
[I] xfce-base/libxfce4util
Available versions: 4.8.2 {debug}
Installed versions: 4.8.2(11:55:54 06/03/2012)(-debug)
Homepage: http://www.xfce.org/projects/libraries/
Description: Xfce's basic utilities library
[I] xfce-base/xfce4-meta
Available versions: 4.8 {minimal +session +svg}
Installed versions: 4.8(00:15:07 10/03/2012)(session svg -minimal)
Description: The Xfce Desktop Environment (meta package)
[I] xfce-base/xfce4-panel
Available versions: 4.8.6 ~4.9.0 {debug}
Installed versions: 4.8.6(23:55:16 08/03/2012)(-debug)
Homepage: http://www.xfce.org/projects/xfce4-panel/
Description: Panel for the Xfce desktop environment
[I] xfce-base/xfce4-session
Available versions: 4.8.2 ~4.8.3 ~4.8.3-r1 {consolekit debug gnome gnome-keyring policykit udev +xfce_plugins_logout}
Installed versions: 4.8.2(23:57:59 08/03/2012)(consolekit gnome policykit udev xfce_plugins_logout -debug -gnome-keyring)
Homepage: http://www.xfce.org/projects/xfce4-session/
Description: Xfce's session manager
[I] xfce-base/xfce4-settings
Available versions: 4.8.3 ~4.9.2 {debug libcanberra libnotify +xklavier}
Installed versions: 4.8.3(23:10:16 09/03/2012)(libnotify xklavier -debug -libcanberra)
Homepage: http://www.xfce.org/projects/xfce4-settings/
Description: Configuration system for the Xfce desktop environment
* xfce-extra/xfce4-appfinder
Available versions: 4.8.0 ~4.9.3 {debug}
Homepage: http://www.xfce.org/projects/xfce4-appfinder/
Description: Application finder and launcher for the Xfce desktop environment
* xfce-extra/xfce4-battery-plugin
Available versions: 1.0.0-r1 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-battery-plugin
Description: A battery monitor panel plugin for the Xfce desktop environment
* xfce-extra/xfce4-cellmodem-plugin
Available versions: 0.0.5 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-cellmodem-plugin
Description: Panel plugin for monitoring cellular modems - GPRS/UMTS(3G)/HSDPA(3.5G)
* xfce-extra/xfce4-clipman-plugin
Available versions: 1.1.3 1.2.2 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-clipman-plugin
Description: A clipboard manager plug-in for the Xfce panel
* xfce-extra/xfce4-cpufreq-plugin
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-cpufreq-plugin
Description: A panel plugin for showing information about cpufreq settings
* xfce-extra/xfce4-cpugraph-plugin
Available versions: 1.0.1 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-cpugraph-plugin
Description: A system load plug-in for the Xfce panel
* xfce-extra/xfce4-datetime-plugin
Available versions: 0.6.1
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-datetime-plugin
Description: A panel plug-in with date, time and embedded calender
* xfce-extra/xfce4-dict
Available versions: 0.6.0
Homepage: http://goodies.xfce.org/projects/applications/xfce4-dict
Description: A dict.org querying application and panel plug-in for the Xfce desktop
* xfce-extra/xfce4-diskperf-plugin
Available versions: 2.3.0
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-diskperf-plugin
Description: Xfce's disk usage and performance panel plugin
* xfce-extra/xfce4-embed-plugin
Available versions: ~0.0.2_pre ~0.8.0 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-embed-plugin
Description: A plug-in for embedding arbitrary application windows into the Xfce panel
* xfce-extra/xfce4-eyes-plugin
Available versions: 4.4.1 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-eyes-plugin
Description: panel plugin that adds eyes which watch your every step
* xfce-extra/xfce4-fsguard-plugin
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-fsguard-plugin
Description: A filesystem guard plug-in for the Xfce panel
* xfce-extra/xfce4-genmon-plugin
Available versions: 3.3.0 3.3.1 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-genmon-plugin
Description: Cyclically spawns the executable, captures its output and displays the result into the panel.
* xfce-extra/xfce4-gvfs-mount
Available versions: ~0.0.4 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-gvfs-mount
Description: A panel plug-in to mount remote filesystems for the Xfce desktop environment
* xfce-extra/xfce4-hdaps
Available versions: 0.0.7 {debug}
Homepage: http://michael.orlitzky.com/code/xfce4-hdaps.php
Description: A plugin to indicate the status of the IBM Hard Drive Active Protection System
* xfce-extra/xfce4-indicator-plugin
Available versions: ~0.4.0 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-indicator-plugin
Description: A panel plugin that uses indicator-applet to show new messages
* xfce-extra/xfce4-kbdleds-plugin
Available versions: ~0.0.6 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-kbdleds-plugin
Description: A panel plug-in to show state of Caps, Num and Scroll Lock keys
* xfce-extra/xfce4-linelight-plugin
Available versions: 0.1.6-r1
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-linelight-plugin
Description: A simple locate based search plug-in for the Xfce panel
* xfce-extra/xfce4-mailwatch-plugin
Available versions: 1.1.0 {debug ipv6 ssl}
Homepage: http://spuriousinterrupt.org/projects/mailwatch
Description: Mail notification panel plugin
* xfce-extra/xfce4-messenger-plugin
Available versions: ~0.1.0
Homepage: http://packages.qa.debian.org/x/xfce4-messenger-plugin.html
Description: A plugin that listens DBus messages and displays received messages
[I] xfce-extra/xfce4-mixer
Available versions: 4.8.0 {alsa debug oss}
Installed versions: 4.8.0(13:24:02 14/03/2012)(alsa oss -debug)
Homepage: http://www.xfce.org/projects/xfce4-mixer/
Description: A volume control application (and panel plug-in) for the Xfce desktop environment
* xfce-extra/xfce4-modemlights-plugin
Available versions: 0.1.3.99 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-modemlights-plugin
Description: A panel plug-in intended to simplify establishing a ppp connection
* xfce-extra/xfce4-mount-plugin
Available versions: 0.5.5 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-mount-plugin
Description: Mount plugin for the Xfce panel
* xfce-extra/xfce4-mpc-plugin
Available versions: 0.3.6 ~0.4.0 ~0.4.2 {debug libmpd}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-mpc-plugin
Description: Music Player Daemon (mpd) panel plugin
* xfce-extra/xfce4-netload-plugin
Available versions: 1.0.0 1.1.0 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-netload-plugin
Description: A network load plug-in for the Xfce panel
* xfce-extra/xfce4-netspeed-plugin
Homepage: http://code.google.com/p/xfce4-netspeed-plugin/
Description: A network transfer rate monitoring panel plug-in, inspired by Gnome's Netspeed applet
* xfce-extra/xfce4-notes-plugin
Available versions: 1.7.7
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-notes-plugin
Description: Xfce4 panel sticky notes plugin
* xfce-extra/xfce4-notifyd
Available versions: 0.2.2 {debug}
Homepage: http://goodies.xfce.org/projects/applications/xfce4-notifyd
Description: Notification daemon for the Xfce desktop environment
* xfce-extra/xfce4-places-plugin
Available versions: 1.2.0-r1 {debug libnotify}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-places-plugin
Description: Places menu plug-in for panel, like GNOME's
* xfce-extra/xfce4-playercontrol-plugin
Available versions: ~0.3.0 {audacious mpd}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-xmms-plugin/
Description: Audacious and MPD panel plugins
[I] xfce-extra/xfce4-power-manager
Available versions: 1.0.10-r1 {debug kernel_linux networkmanager policykit +xfce_plugins_brightness}
Installed versions: 1.0.10-r1(13:33:24 14/03/2012)(kernel_linux networkmanager policykit xfce_plugins_brightness -debug)
Homepage: http://goodies.xfce.org/projects/applications/xfce4-power-manager
Description: Power manager for the Xfce desktop environment
* xfce-extra/xfce4-quicklauncher-plugin
Available versions: 1.9.4-r1 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-quicklauncher-plugin
Description: A quicklauncher plug-in for the Xfce panel
* xfce-extra/xfce4-radio-plugin
Available versions: 0.5.1 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-radio-plugin
Description: V4L radio device control plug-in for the Xfce desktop environment
[I] xfce-extra/xfce4-screenshooter
Available versions: 1.8.0 {debug}
Installed versions: 1.8.0(23:03:13 29/04/2012)(-debug)
Homepage: http://goodies.xfce.org/projects/applications/xfce4-screenshooter
Description: Xfce4 screenshooter application and panel plugin
[I] xfce-extra/xfce4-sensors-plugin
Available versions: 1.2.3 {+acpi debug hddtemp libnotify lm_sensors video_cards_nvidia}
Installed versions: 1.2.3(13:11:50 14/03/2012)(acpi hddtemp libnotify lm_sensors -debug -video_cards_nvidia)
Description: acpi, lm_sensors and hddtemp panel plugin
* xfce-extra/xfce4-smartbookmark-plugin
Available versions: 0.4.2 0.4.4 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-smartbookmark-plugin
Description: Smart bookmark plug-in for the Xfce desktop environment
* xfce-extra/xfce4-soundmenu-plugin
Available versions: 0.2.4.2 {debug +glyr lastfm}
Homepage: http://code.google.com/p/dissonance/
Description: A panel plug-in to control MPRIS2 compatible players like Pragha (from the same authors)
* xfce-extra/xfce4-systemload-plugin
Available versions: 1.0.0 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-systemload-plugin
Description: System load plug-in for Xfce panel
[I] xfce-extra/xfce4-taskmanager
Installed versions: 1.0.0(13:25:06 14/03/2012)(-debug)
Homepage: http://goodies.xfce.org/projects/applications/xfce4-taskmanager
Description: Task Manager
* xfce-extra/xfce4-time-out-plugin
Available versions: 1.0.0 ~1.0.0-r1
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-time-out-plugin
Description: A panel plug-in to take periodical breaks from the computer
* xfce-extra/xfce4-timer-plugin
Available versions: 0.6.2 0.6.3 ~0.6.4
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-timer-plugin
Description: A simple timer plug-in for the Xfce desktop environment
* xfce-extra/xfce4-vala
Available versions: ~4.8.1
Homepage: http://wiki.xfce.org/vala-bindings
Description: Vala bindings for the Xfce desktop environment
* xfce-extra/xfce4-verve-plugin
Available versions: 1.0.0 {dbus}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-verve-plugin
Description: A comfortable command line plugin for the Xfce panel
* xfce-extra/xfce4-volumed
Available versions: 0.1.13 {alsa debug libnotify oss}
Homepage: https://launchpad.net/xfce4-volumed
Description: Daemon to control volume up/down and mute keys
* xfce-extra/xfce4-wavelan-plugin
Available versions: 0.5.6
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-wavelan-plugin
Description: Wireless monitor panel plugin
* xfce-extra/xfce4-weather-plugin
Available versions: 0.7.4-r1 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-weather-plugin
Description: A weather plug-in for the Xfce desktop environment
* xfce-extra/xfce4-wmdock-plugin
Available versions: 0.3.4 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-wmdock-plugin
Description: a compatibility layer for running WindowMaker dockapps on Xfce4.
* xfce-extra/xfce4-xkb-plugin
Available versions: 0.5.4.3 {debug}
Homepage: http://goodies.xfce.org/projects/panel-plugins/xfce4-xkb-plugin
Description: XKB layout switching panel plug-in for the Xfce desktop environment
Found 55 matches.
