[Risolto] Linux sul mio PC: Il Ritorno... è Gentoo!
- Zievatron
Re: Linux sul mio PC: Il Ritorno... è Gentoo!
Infatti, è passato ora a (5 of 192)
OK. Allora, Buona Notte!
...ehehehe ne vedrai quando emergerei un DE, li ci sarà ancor di più di aspettare: per quello uso il metodo chroot, almeno il PC è disponibile mentre compila!
Fammi sapere domani mattina a che punto è arrivato...
- Zievatron
E' andato bene fino a questo punto, poi sono comparsi degli errori:
./.libs/libarchive.so: undefined reference to `compression_unsupported_encoder'
collect2: ld returned 1 exit status
make[1]: *** [bsdcpio] Errore 1
make[1]: *** Attesa dei processi non terminati....
make[1]: *** [bsdtar] Errore 1
make[1]: Leaving directory `/var/tmp/portage/app-arch/libarchive-3.0.3/work/libarchive-3.0.3'
make: *** [all] Errore 2
* ERROR: app-arch/libarchive-3.0.3 failed (compile phase):
* emake failed
* If you need support, post the output of 'emerge --info =app-arch/libarchive-3.0.3',
* the complete build log and the output of 'emerge -pqv =app-arch/libarchive-3.0.3'.
* The complete build log is located at '/var/tmp/portage/app-arch/libarchive-3.0.3/temp/build.log'.
* The ebuild environment file is located at '/var/tmp/portage/app-arch/libarchive-3.0.3/temp/environment'.
* S: '/var/tmp/portage/app-arch/libarchive-3.0.3/work/libarchive-3.0.3'
>>> Failed to emerge app-arch/libarchive-3.0.3, Log file:
* Messages for package dev-lang/tcl-8.5.9:
* PLEASE NOTE: You are compiling tcl-8.5.9 with
* threading enabled.
* Threading is not supported by all applications
* that compile against tcl. You use threading at
* your own discretion.
* If you're upgrading from <dev-lang/tcl-8.5, you must recompile the other
* packages on your system that link with tcl after the upgrade
* completes. To perform this action, please run revdep-rebuild
* in package app-portage/gentoolkit.
* If you have dev-lang/tk and dev-tcltk/tclx installed you should
* upgrade them before this recompilation, too,
* Messages for package app-text/libpaper-1.1.24-r1:
* run "paperconf -p letter" as root to use letter-pagesizes
* or paperconf with normal user privileges.
* Messages for package app-text/djvu-3.5.24:
* For djviewer or browser plugin, emerge app-text/djview.
* Messages for package x11-libs/pixman-0.24.0:
* Running elibtoolize in: pixman-0.24.0/
* We've already been run in this tree; you should
* avoid this if possible (perhaps by filing a bug)
* Messages for package x11-proto/xcb-proto-1.6-r2:
* Deleting byte-compiled Python modules needlessly generated by build system:
* /var/tmp/portage/x11-proto/xcb-proto-1.6-r2/image/usr/lib64/python2.7/site-packages/xcbgen/expr.pyc
* /var/tmp/portage/x11-proto/xcb-proto-1.6-r2/image/usr/lib64/python2.7/site-packages/xcbgen/expr.pyo
* /var/tmp/portage/x11-proto/xcb-proto-1.6-r2/image/usr/lib64/python2.7/site-packages/xcbgen/matcher.pyc
* /var/tmp/portage/x11-proto/xcb-proto-1.6-r2/image/usr/lib64/python2.7/site-packages/xcbgen/xtypes.pyo
* /var/tmp/portage/x11-proto/xcb-proto-1.6-r2/image/usr/lib64/python2.7/site-packages/xcbgen/matcher.pyo
* /var/tmp/portage/x11-proto/xcb-proto-1.6-r2/image/usr/lib64/python2.7/site-packages/xcbgen/state.pyc
* /var/tmp/portage/x11-proto/xcb-proto-1.6-r2/image/usr/lib64/python2.7/site-packages/xcbgen/__init__.pyc
* /var/tmp/portage/x11-proto/xcb-proto-1.6-r2/image/usr/lib64/python2.7/site-packages/xcbgen/xtypes.pyc
* /var/tmp/portage/x11-proto/xcb-proto-1.6-r2/image/usr/lib64/python2.7/site-packages/xcbgen/error.pyc
* /var/tmp/portage/x11-proto/xcb-proto-1.6-r2/image/usr/lib64/python2.7/site-packages/xcbgen/error.pyo
* /var/tmp/portage/x11-proto/xcb-proto-1.6-r2/image/usr/lib64/python2.7/site-packages/xcbgen/state.pyo
* /var/tmp/portage/x11-proto/xcb-proto-1.6-r2/image/usr/lib64/python2.7/site-packages/xcbgen/__init__.pyo
* Please rebuild both libxcb and xcb-util if you are upgrading from version 1.6
* Messages for package app-arch/libarchive-3.0.3:
* emake failed
* Regenerating GNU info directory index...
* Processed 73 info files.
Allora riproviamo:
Di cui mi riporti la parte finale...
se richiesto scegli l'opzione "-5"
di cui mi dici solo se hai usato o meno l'opzione -5
A scanso di equivoci mi fai vedere anche:
cosi vediamo con quale profilo gcc sta compilando!
Sai per caso a quanti pacchetti era arrivato?
restituisce qualcosa
emerge --sync
etc-update
emerge -DNu world
emerge syslog-ng
gcc-config -l
qlop -l
- Zievatron
emerge --sync
Number of files: 151163
Number of files transferred: 344
Total file size: 219336440 bytes
Total transferred file size: 1740927 bytes
Literal data: 1740927 bytes
Matched data: 0 bytes
File list size: 3607136
File list generation time: 0.002 seconds
File list transfer time: 0.000 seconds
Total bytes sent: 47118
Total bytes received: 5479710
sent 47118 bytes received 5479710 bytes 70405.45 bytes/sec
total size is 219336440 speedup is 39.69
Performing Global Updates:
(Could take a couple of minutes if you have a lot of binary packages.)
.='update pass' *='binary update' #='/var/db update' @='/var/db move'
s='/var/db SLOT move' %='binary move' S='binary SLOT move'
p='update /etc/portage/package.*'
/usr/portage/profiles/updates/1Q-2012............
etc-update
Scanning Configuration files...
Exiting: Nothing left to do; exiting. :)
emerge -DNu world
The following USE changes are necessary to proceed:
#required by dev-vcs/git-1.7.3.4-r1[subversion,perl], required by sys-devel/gettext-0.18.1.1-r1[git], required by x11-misc/shared-mime-info-1.0, required by x11-misc/xdg-utils-1.1.0_rc1_p20111003, required by net-print/cups-1.4.8-r1[X], required by x11-libs/gtk+-3.0.12-r1[cups], required by gnome-extra/polkit-gnome-0.105, required by sys-auth/polkit-0.104-r1[gtk], required by sys-auth/consolekit-0.4.5-r1[policykit], required by sys-auth/pambase-20101024-r2[consolekit], required by sys-apps/openrc-0.9.8.4[pam], required by dev-db/mysql-init-scripts-2.0_pre1-r2, required by dev-db/mysql-5.1.61[-minimal], required by virtual/mysql-5.1, required by dev-libs/apr-util-1.3.12
=dev-vcs/subversion-1.6.17-r7 -dso
Use --autounmask-write to write changes to config files (honoring CONFIG_PROTECT).
emerge syslog-ng
>>> Installing (1 of 1) app-admin/syslog-ng-3.2.5
* It is highly recommended that app-admin/logrotate be emerged to
* manage the log files. syslog-ng installs a file in /etc/logrotate.d
* for logrotate to use.
>>> Recording app-admin/syslog-ng in "world" favorites file...
* Messages for package app-admin/syslog-ng-3.2.5:
>>> Auto-cleaning packages...
>>> No outdated packages were found on your system.
* GNU info directory index is up-to-date.
gcc-config -l
[1] x86_64-pc-linux-gnu-4.5.3 *
qlop -l
bash: qlop: command not found
Dai:
per sistemare le dipendenze.... e mi posti tutto...
revdep-rebuild
- Zievatron
Aaargghh! Ed io che stavo ancora aspettando un nuovo messaggio! Com'è che questo non l'ho visto?conoscenza ha scritto:Dai:per sistemare le dipendenze.... e mi posti tutto...Codice: Seleziona tutto
revdep-rebuild
Comunque, ho ancora un "command not found".
non hai ricevuto la notifica di risposta tramite email?
dai:
emerge --sync
emerge gentoolkit
revdep-rebuild
quando ci sono errori me li riporti!
dai:
emerge --sync
emerge gentoolkit
revdep-rebuild
- Zievatron
Sembra che ne ho persa una. Ma può essere che sia rimasta impigliata in un pacco di spam che ho cestinato.conoscenza ha scritto:non hai ricevuto la notifica di risposta tramite email?
Non ho visto errori.
non saprei dirti: anche a me per un giorno non ho ricevuto le notifiche... avevo segnalato ma tutto era ok!
Fammi sapere se perdi altre notifiche!
Fatto anche "revdep-rebuild"?
Continua con "emerge syslog-ng"....
