Messaggi: 1657 Iscritto il: mercoledì 21 dicembre 2011, 23:49
Messaggio
da Zievatron » lunedì 5 marzo 2012, 11:43
conoscenza ha scritto: Se è molto lungo allora dai:
E' il grub 0.97 r10
Se questo da errori, riporta e fermati pure qui
Mi sembra uguale all'ultima volta
Total: 31 packages (29 new, 2 reinstalls), Size of downloads: 84,007 kB
* Error: circular dependencies:
(virtual/jdk-1.6.0::gentoo, ebuild scheduled for merge) depends on
(dev-java/icedtea-bin-6.1.11.1::gentoo, ebuild scheduled for merge) (runtime)
(x11-libs/gtk+-2.24.8-r1::gentoo, ebuild scheduled for merge) (runtime)
(net-print/cups-1.4.8-r1::gentoo, ebuild scheduled for merge) (buildtime)
(virtual/jre-1.6.0::gentoo, ebuild scheduled for merge) (buildtime)
(virtual/jdk-1.6.0::gentoo, ebuild scheduled for merge) (runtime)
It might be possible to break this cycle
by applying any of the following changes:
- dev-java/icedtea-bin-6.1.11.1 (Change USE: -X)
- x11-libs/gtk+-2.24.8-r1 (Change USE: -cups)
- net-print/cups-1.4.8-r1 (Change USE: -java)
Note that this change can be reverted, once the package has been installed.
Note that the dependency graph contains a lot of cycles.
Several changes might be required to resolve all cycles.
Temporarily changing some use flag for all packages might be the better option.
(serve per la pulizia di pacchettiche per ora non servono più)
(per il controllo incrociato delle dipendeze)
* Dependencies could not be completely resolved due to
* the following required packages not being installed:
* >=dev-db/libdbi-drivers-0.8.3 pulled in by:
* dev-db/libdbi-0.8.3
* Have you forgotten to do a complete update prior to depclean? The
* most comprehensive command for this purpose is as follows:
* emerge --update --newuse --deep --with-bdeps=y @world
* Note that the --with-bdeps=y option is not required in many
* situations. Refer to the emerge manual page (run `man emerge`)
* for more information about --with-bdeps.
* Also, note that it may be necessary to manually uninstall
* packages that no longer exist in the portage tree, since it may
* not be possible to satisfy their dependencies.
Messaggi: 3821 Iscritto il: venerdì 2 dicembre 2011, 23:27
Messaggio
da conoscenza » lunedì 5 marzo 2012, 11:54
mi fai vedere:
Posta tutto...
Sono allergico a mele morsicate e a
finestre con tende .
Messaggio
da Zievatron » lunedì 5 marzo 2012, 12:04
conoscenza ha scritto: mi fai vedere:
Posta tutto...
darkstar / # emerge -DNup world
These are the packages that would be merged, in order:
[nomerge ] app-admin/syslog-ng-3.2.5 USE="ipv6 pcre sql ssl tcpd -caps -hardened (-selinux) -spoof-source"
[nomerge ] dev-db/libdbi-0.8.3 USE="-doc"
[ebuild N ] dev-db/libdbi-drivers-0.8.3 USE="mysql sqlite -bindist -doc (-firebird) -oci8 -postgres -sqlite3" 0 kB
[nomerge ] dev-perl/DBD-mysql-4.01.7
[nomerge ] virtual/mysql-5.1 USE="embedded -minimal -static"
[ebuild N ] dev-db/mysql-5.1.61 USE="berkdb community embedded perl ssl -big-tables -cluster -debug -extraengine -latin1 -max-idx-128 -minimal -pbxt -profiling (-selinux) -static -test -xtradb" 0 kB
[ebuild N ] dev-perl/DBD-mysql-4.01.7 0 kB
[nomerge ] dev-python/pygtksourceview-2.10.1 USE="-debug -doc"
[nomerge ] dev-python/pygtk-2.24.0-r2 USE="-doc -examples -test"
[nomerge ] gnome-base/libglade-2.6.4 USE="static-libs -doc -test"
[nomerge ] x11-libs/gtk+-2.24.8-r1 USE="cups introspection (-aqua) -debug -doc -examples -test -vim-syntax -xinerama"
[nomerge ] net-print/cups-1.4.8-r1 USE="X acl dbus filters gnutls java jpeg ldap pam perl png python ssl static-libs threads tiff -debug -kerberos -php -slp -xinetd" LINGUAS="-da -de -es -eu -fi -fr -id -it -ja -ko -nl -no -pl -pt -pt_BR -ru -sv -zh -zh_TW"
[nomerge ] app-text/poppler-0.16.7 USE="cairo curl cxx introspection jpeg jpeg2k lcms png qt4 utils xpdf-headers -cjk -debug -doc -exceptions"
[nomerge ] media-libs/openjpeg-1.4-r1 USE="-doc -test"
[nomerge ] dev-util/cmake-2.8.6-r4 USE="ncurses qt4 -emacs -test -vim-syntax"
[nomerge ] x11-libs/qt-gui-4.7.4-r1 USE="accessibility cups dbus exceptions glib mng nas pch qt3support tiff (-aqua) -debug -egl -gtkstyle -nis -private-headers -raster -trace -xinerama"
[nomerge ] media-libs/nas-1.9.2 USE="-doc"
[nomerge ] x11-libs/libXaw-1.0.9 USE="static-libs -doc"
[nomerge ] x11-libs/libXpm-3.5.9 USE="static-libs"
[nomerge ] sys-devel/gettext-0.18.1.1-r1 USE="acl cxx git nls openmp -doc -emacs"
[ebuild R ] dev-vcs/git-1.7.3.4-r1 USE="bash-completion* blksha1 cgi* curl gtk* iconv perl subversion* threads tk* webdav -cvs -doc -emacs (-ppcsha1) -xinetd" 2,862 kB
[ebuild N ] dev-vcs/subversion-1.6.17-r7 USE="bash-completion berkdb extras java nls perl python webdav-neon -apache2 -ctypes-python -debug -doc -dso -emacs -gnome-keyring -kde -ruby -sasl -vim-syntax -webdav-serf" 5,376 kB
[ebuild N ] dev-libs/apr-util-1.3.12 USE="berkdb gdbm ldap mysql sqlite static-libs -doc -freetds -odbc -postgres" 594 kB
[ebuild N ] x11-libs/qt-qt3support-4.7.4 USE="accessibility exceptions pch (-aqua) -debug -kde -phonon" 0 kB
[ebuild N ] x11-libs/qt-sql-4.7.4 USE="exceptions iconv mysql pch qt3support sqlite (-aqua) -debug -firebird -freetds -odbc -postgres" 0 kB
[ebuild N ] virtual/mysql-5.1 USE="embedded -minimal -static" 0 kB
[nomerge ] virtual/ssh-0 USE="-minimal"
[nomerge ] net-misc/openssh-5.8_p1-r1 USE="X* hpn ldap* pam tcpd -X509 -kerberos -libedit (-selinux) -skey -static"
[nomerge ] sys-auth/pambase-20101024-r2 USE="consolekit* cracklib sha512 -debug -gnome-keyring -minimal -mktemp -pam_krb5 -pam_ssh -passwdqc (-selinux)"
[nomerge ] sys-auth/consolekit-0.4.5-r1 USE="pam policykit -debug -doc -test"
[nomerge ] sys-auth/polkit-0.104-r1 USE="gtk introspection nls pam -debug -doc -examples -kde (-systemd)"
[ebuild N ] gnome-extra/polkit-gnome-0.105 304 kB
[ebuild N ] x11-libs/gtk+-3.0.12-r1 USE="cups introspection (-aqua) -debug -doc -examples -test -vim-syntax -xinerama" 12,810 kB
[nomerge ] dev-vcs/git-1.7.3.4-r1 USE="bash-completion* blksha1 cgi* curl gtk* iconv perl subversion* threads tk* webdav -cvs -doc -emacs (-ppcsha1) -xinetd"
[nomerge ] dev-python/pygobject-2.28.6-r51 USE="introspection -doc -examples -libffi -test"
[nomerge ] dev-python/pygobject-3.0.2 USE="cairo threads -examples -test"
[nomerge ] dev-libs/gobject-introspection-1.30.0-r2 USE="-doc -test"
[nomerge ] x11-libs/cairo-1.10.2-r1 USE="X glib opengl qt4 static-libs svg xcb (-aqua) -debug -directfb -doc (-drm) (-gallium) (-openvg)"
[ebuild N ] net-print/foomatic-filters-4.0.9 USE="cups dbus" 0 kB
[ebuild N ] app-text/ghostscript-gpl-9.04-r4 USE="X cups dbus djvu gtk jpeg2k static-libs -bindist -idn" LINGUAS="-ja -ko -zh_CN -zh_TW" 0 kB
[ebuild N ] net-print/cups-1.4.8-r1 USE="X acl dbus filters gnutls java jpeg ldap pam perl png python ssl static-libs threads tiff -debug -kerberos -php -slp -xinetd" LINGUAS="-da -de -es -eu -fi -fr -id -it -ja -ko -nl -no -pl -pt -pt_BR -ru -sv -zh -zh_TW" 0 kB
[ebuild N ] app-text/poppler-0.16.7 USE="cairo curl cxx introspection jpeg jpeg2k lcms png qt4 utils xpdf-headers -cjk -debug -doc -exceptions" 0 kB
[ebuild N ] media-libs/openjpeg-1.4-r1 USE="-doc -test" 0 kB
[ebuild N ] dev-util/cmake-2.8.6-r4 USE="ncurses qt4 -emacs -test -vim-syntax" 0 kB
[ebuild N ] x11-libs/qt-gui-4.7.4-r1 USE="accessibility cups dbus exceptions glib mng nas pch qt3support tiff (-aqua) -debug -egl -gtkstyle -nis -private-headers -raster -trace -xinerama" 0 kB
[ebuild N ] dev-python/pygobject-3.0.2 USE="cairo threads -examples -test" 533 kB
[ebuild N ] dev-python/pygtksourceview-2.10.1 USE="-debug -doc" 284 kB
[ebuild N ] dev-python/pygtk-2.24.0-r2 USE="-doc -examples -test" 2,306 kB
[ebuild N ] dev-python/pycairo-1.10.0-r2 USE="svg -doc -examples -test" 634 kB
[ebuild N ] x11-libs/pango-1.28.4 USE="X introspection -debug -doc -test" 0 kB
[ebuild N ] x11-libs/cairo-1.10.2-r1 USE="X glib opengl qt4 static-libs svg xcb (-aqua) -debug -directfb -doc (-drm) (-gallium) (-openvg)" 0 kB
[nomerge ] dev-lang/python-3.2.2 [2.7.2-r3, 3.1.4-r3] USE="gdbm ipv6 ncurses readline sqlite ssl threads tk (wide-unicode) xml -build -doc -examples -wininst"
[nomerge ] sys-libs/gdbm-1.8.3-r4 USE="berkdb"
[ebuild R ] sys-libs/db-4.8.30 USE="cxx java* tcl* -doc -examples -test" 22,351 kB
[ebuild N ] virtual/jre-1.6.0 0 kB
[ebuild N ] virtual/jdk-1.6.0 0 kB
[ebuild N ] dev-java/icedtea-bin-6.1.11.1 USE="X alsa -cjk -cups -doc -examples -nsplugin -source" 34,387 kB
[ebuild N ] x11-libs/gtksourceview-2.10.5-r1 USE="-doc -glade -test" 1,224 kB
[ebuild N ] gnome-base/libglade-2.6.4 USE="static-libs -doc -test" 348 kB
[ebuild N ] x11-libs/gtk+-2.24.8-r1 USE="cups introspection (-aqua) -debug -doc -examples -test -vim-syntax -xinerama" 0 kB
Messaggio
da conoscenza » lunedì 5 marzo 2012, 12:13
revdep-rebuild -p
Messaggio
da Zievatron » lunedì 5 marzo 2012, 13:26
conoscenza ha scritto: revdep-rebuild -p
Strano. Ero convinti di avrti già risposto.
* Configuring search environment for revdep-rebuild
* Checking reverse dependencies
* Packages containing binaries and libraries broken by a package update
* will be emerged.
* Collecting system binaries and libraries
* Generated new 1_files.rr
* Collecting complete LD_LIBRARY_PATH
* Generated new 2_ldpath.rr
* Checking dynamic linking consistency
[ 100% ]
* Dynamic linking on your system is consistent... All done.
Messaggio
da conoscenza » lunedì 5 marzo 2012, 13:39
revdep sta bene... e l'aggiornamento che non va!
...mmm ci ritorneremo!
Ti ha emerso grub e non grub2: per il momento teniamo quello e poi vediamo di aggiornarlo.
Mi fai vedere
e
Messaggio
da Zievatron » lunedì 5 marzo 2012, 14:02
cat /boot/grub/grub.conf
# This is a sample grub.conf for use with Genkernel, per the Gentoo handbook
# http://www.gentoo.org/doc/en/handbook/handbook-x86.xml?part=1&chap=10#doc_chap2
# If you are not using Genkernel and you need help creating this file, you
# should consult the handbook. Alternatively, consult the grub.conf.sample that
# is included with the Grub documentation.
default 0
timeout 30
#splashimage=(hd0,0)/boot/grub/splash.xpm.gz
#title Gentoo Linux 2.6.24-r5
#root (hd0,0)
#kernel /boot/kernel-genkernel-x86-2.6.24-gentoo-r5 root=/dev/ram0 real_root=/dev/sda3
#initrd /boot/initramfs-genkernel-x86-2.6.24-gentoo-r5
# vim:ft=conf:
cat /etc/portage/package.use
=dev-java/icedtea-bin-6.1.11.1 -cups
=dev-vcs/subversion-1.6.17-r7 -dso emerge --sync
Messaggio
da conoscenza » lunedì 5 marzo 2012, 15:42
...come è finito "emerge --sync" in /etc/portage/package.use? Edita:
nano /etc/portage/package.use
e cancella "emerge --sync" alla seconda riga.
riprova quindi a dare:
emerge --sync
emerge -DNu world
Che nome utente utilizzi di solito?
Messaggio
da Zievatron » lunedì 5 marzo 2012, 16:00
conoscenza ha scritto: ...come è finito "emerge --sync" in /etc/portage/package.use?
Bhò? Avrà fatto visita ad un amico?
emerge -DNu world
Continua a dare:
Su Salice sono unknow
Messaggio
da conoscenza » lunedì 5 marzo 2012, 18:38
Allora setta prima la password per l'utente root...
dai il comando "passwd"
e poi insierisci password come richiesto!
Aggiungi poi l'utente "unknow"....dando:
useradd -m -G users,usb,video,cdrom,wheel,audio -s /bin/bash unknow
