Gentoo: Quel demonio di xfconf non risponde
Re: Gentoo: Quel demonio di xfconf non risponde
Non è che in quelle righe c'era scritto come abilitare xfconf?
mi dai un
cat /etc/make.conf
Messaggio da Zievatron »
conoscenza ha scritto:Non è che in quelle righe c'era scritto come abilitare xfconf?
mi dai un
cat /etc/make.conf
Allora lo riemergo per vedere le ultime righe?
darkstar / # cat /etc/make.conf
# These settings were set by the catalyst build script that automatically
# built this stage.
# Please consult /usr/share/portage/config/make.conf.example for a more
# detailed example.
CFLAGS="-march=native -O2 -pipe"
CXXFLAGS="${CFLAGS}"
# WARNING: Changing your CHOST is not something that should be done lightly.
# Please consult http://www.gentoo.org/doc/en/change-chost.xml before changing.
CHOST="x86_64-pc-linux-gnu"
# These are the USE flags that were used in addition to what is provided by the
# profile used for building.
USE="mmx sse sse2 X Xaw3d a52 aac aalib alsa ao bash-completion bcmath gtk xorg glibc-omitfp mpi smp cups custom-cflags \
custom-optimization custom-cpuopts xvmc gtk extras audiofile cairo cdda cddb cdparanoia cdr cgi cracklib cdr css cxx dbus \
dga djvu dri gdu device-mapper gd posix disk-partition automount icu ntfs fat thunar gpm gnome mysql sql webkit xulrunner \
kdrive dts dv dvb dvd dvdr eds encode evo exif axpat fastcgi ffmpeg fftw flac foomaticdb fortran gdbm policykit sqlite hddtemp gpm \
ggi gimp ginac gimp gnutls gphoto2 gps gsm gls graphviz gstreamer hal java jbig jpeg jpeg2k lame twolame libv4l libv4l2 libgda lock \
lzo matroska mng mp3 mp4 mpeg mtp mplayer musepack musicbrainz nas nptl openal ogg openexr openmp oss pch perl pda pcre pcntl \
pdf plasma posix png prelude ppds python pulseaudio qt4 raw scanner semantic-desktop session shorten smartcard sndfile speex spell ssl startup-notification svg \
svga tcl tk threads syslog subversion glib mpi-threads fuse theora udev v4l v4l2 vcd win32codecs vorbis wapack wmf x264 xcb xft \
xine xpm xv xvid optimized-qmake fontconfig imagemagick mjpeg floppy xrandr midi timidity curl libass libcaca vdr faac faad \
schroedinger glitz cleartype qt3support mono network static-libs opengl -mmxext -3dnow -3dnowext lm_sensors sip wav networkmanager \
dso php_targets_php5-2 embedded write zip zlib"
INPUT_DEVICES="mouse keyboard evdev"
VIDEO_CARDS="radeon"
MAKEOPTS="-j2"
ACCEPT_LICENSE="@EULA"
EMERGE_DEFAUL_OPTS="--autounmask=n"
LINGUAS="it"
Visto che questa storia va avanti già da un po'.
Provo a riaggiornare Gentoo.
Fatta la sincronizzazione, mi compare il suggerimento di aggiornare portage.
Eseguo.
Suggerimento di leggere una news.
Eseguo.
Però non so se mi sta dicendo una cosa importante. :U
Dice così:
darkstar / # eselect news read new
2012-05-21-portage-config-protect-if-modified
  Title                     Portage config-protect-if-modified default
  Author                    Zac Medico <zmedico@gentoo.org>
  Posted                    2012-05-21
  Revision                  1
Beginning with sys-apps/portage-2.1.10.61, FEATURES=config-protect-if-modified
is enabled by default. This causes the CONFIG_PROTECT behavior to be skipped
for files that have not been modified since they were installed.
If you would like to disable this behavior by default, then set
FEATURES="-config-protect-if-modified" in make.conf. See the make.conf(5) man
page for more information about this feature.
ti dice che i file di configurazione non saranno toccati automaticamente: è un bene che sia cosi.
Per i xfconf, attualmente, non saprei come muovermi.
EDIT:
prova a dare:
xfconf-query -c xfce4-panel -l
