emerge openldap
>>> Verifying ebuild manifests
>>> Emerging (1 of 1) net-nds/openldap-2.4.28-r1
* openldap-2.4.28.tgz RMD160 SHA1 SHA256 size ;-) ... [ ok ]
* rfc2307bis.schema-20100722 RMD160 SHA1 SHA256 size ;-) ... [ ok ]
* ERROR: net-nds/openldap-2.4.28-r1 failed (setup phase):
* To build the ldapc++ library you must emerge openldap with sasl support
* Call stack:
* ebuild.sh, line 85: Called pkg_setup
* openldap-2.4.28-r1.ebuild, line 215: Called die
* The specific snippet of code:
* die "To build the ldapc++ library you must emerge openldap with sasl support"
* If you need support, post the output of 'emerge --info =net-nds/openldap-2.4.28-r1',
* the complete build log and the output of 'emerge -pqv =net-nds/openldap-2.4.28-r1'.
* The complete build log is located at '/var/tmp/portage/net-nds/openldap-2.4.28-r1/temp/build.log'.
* The ebuild environment file is located at '/var/tmp/portage/net-nds/openldap-2.4.28-r1/temp/die.env'.
* S: '/var/tmp/portage/net-nds/openldap-2.4.28-r1/work/openldap-2.4.28'
>>> Failed to emerge net-nds/openldap-2.4.28-r1, Log file:
* Messages for package net-nds/openldap-2.4.28-r1:
* Call stack:
conoscenza ha scritto:No!
dai
etc-update
se richiesto opzione -5
emerge --sync
poi
emerge xfce4-meta
tanto si dira dietro openlap
Aaaarrrgghhh!!!
Io, invece, ho pensato di aver fatto una domanda superflua e l'ho fatto partire senza aspettare la risposta.
Ora è arrivato a (12 of 230).
>>> Emerging (31 of 230) net-nds/openldap-2.4.28-r1
* Call stack:
* Messages for package x11-libs/libxcb-1.7:
* Running elibtoolize in: libxcb-1.7/
* We've already been run in this tree; you should
* avoid this if possible (perhaps by filing a bug)
* Messages for package sys-fs/lvm2-2.02.88:
* Warning, we no longer overwrite /sbin/lvm and /sbin/dmsetup with
* their static versions. If you need the static binaries,
* you must append .static to the filename!
* USE flag nocman is deprecated and replaced
* with the cman USE flag.
* USE flags clvm and cman are masked
* by default and need to be unmasked to be used
* If you are using genkernel and root-on-LVM, rebuild the initramfs.
* lvm volumes are no longer automatically created for
* baselayout-2 users. If you are using baselayout-2, be sure to
* run: # rc-update add lvm boot
* Do NOT add it if you are still using baselayout-1.
* Call stack:
* Regenerating GNU info directory index...
* Processed 81 info files.
