Gentoo notebook: Aggiornamento in difficoltà
Re: Gentoo notebook: Aggiornamento in difficoltà
Messaggio da Zievatron »
darkstar / # ls -l /etc/portage/
totale 20
drwxr-xr-x 2 root root 4096 12 lug 19.43 bin
-rw-r--r-- 1 root root   54 29 mar 15.01 package.keywords
-rw-r--r-- 1 root root   25 15 lug 01.16 package.mask
drwxr-xr-x 2 root root 4096 12 lug 19.43 postsync.d
drwxr-xr-x 3 root root 4096 16 feb 12.29 savedconfig
Ma i due mascheramenti di prima hanno avuto l'effetto che dovevano avere?
conoscenza ha scritto:...poi prova
emerge -pv xfce-base/xfce4-session-4.10.0
emerge -pv xfce-base/libxfce4ui-4.10.0
Per entrambi mi risponde:
 is not a valid package atom.
!!! Please check ebuild(5) for full details.
mi documento e faccio sapere...
Qui siamo fermi o ci sono stati passi in avanti?
come mai non hai nessun ./package.umask?
mi faresti vedere:
cat /etc/portage/package.keywords
cat /etc/portage/package.mask
poi dai:
etc-update (-5 se serve)
emerge --sync
emerge --depclean
emerge -DNu world
Fermi. Aspettavo te.
darkstar / # cat /etc/portage/package.keywords
app-portage/portato ~amd64
darkstar / # cat /etc/portage/package.mask
=x11-libs/libwnck-2.30.7
Ora provo ad emergere.
Mi suggerisce questo:
 * Dependencies could not be completely resolved due to
 * the following required packages not being installed:
 *   x11-misc/xdg-user-dirs-gtk pulled in by:
 *     x11-misc/xdg-user-dirs-0.14
 * Have you forgotten to do a complete update prior to depclean? The
 * most comprehensive command for this purpose is as follows:
 *   emerge --update --newuse --deep --with-bdeps=y @world
 * Note that the --with-bdeps=y option is not required in many
 * situations. Refer to the emerge manual page (run `man emerge`)
 * for more information about --with-bdeps.
 * Also, note that it may be necessary to manually uninstall
 * packages that no longer exist in the portage tree, since it may
 * not be possible to satisfy their dependencies.
Provo ad eseguire il comando suggerito.
EDIT:
108 pacchetti! :s
Però, si è fermato dopo 15.
collect2: ld returned 1 exit status
make[2]: *** [xdg-user-dirs-gtk-update] Errore 1
make[2]: Leaving directory `/var/tmp/portage/x11-misc/xdg-user-dirs-gtk-0.9/work/xdg-user-dirs-gtk-0.9'
make[1]: *** [all-recursive] Errore 1
make[1]: Leaving directory `/var/tmp/portage/x11-misc/xdg-user-dirs-gtk-0.9/work/xdg-user-dirs-gtk-0.9'
make: *** [all] Errore 2
 * ERROR: x11-misc/xdg-user-dirs-gtk-0.9 failed (compile phase):
 *   emake failed
 * If you need support, post the output of `emerge --info '=x11-misc/xdg-user-dirs-gtk-0.9'`,
 * the complete build log and the output of `emerge -pqv '=x11-misc/xdg-user-dirs-gtk-0.9'`.
 * The complete build log is located at '/var/tmp/portage/x11-misc/xdg-user-dirs-gtk-0.9/temp/build.log'.
 * The ebuild environment file is located at '/var/tmp/portage/x11-misc/xdg-user-dirs-gtk-0.9/temp/environment'.
 * Working directory: '/var/tmp/portage/x11-misc/xdg-user-dirs-gtk-0.9/work/xdg-user-dirs-gtk-0.9'
 * S: '/var/tmp/portage/x11-misc/xdg-user-dirs-gtk-0.9/work/xdg-user-dirs-gtk-0.9'
>>> Failed to emerge x11-misc/xdg-user-dirs-gtk-0.9, Log file:
 * Messages for package x11-misc/xdg-user-dirs-gtk-0.9:
 *   emake failed
 * GNU info directory index is up-to-date.
 * After world updates, it is important to remove obsolete packages with
 * emerge --depclean. Refer to `man emerge` for more information.
Prima di tutto:
in "/etc/portage/package.keywords", cancella una della doppia riga: "app-portage/portato ~amd64". Due non servono.
Bravo che hai seguito il suggerimento.
Dai:
emerge --depclean
emerge -DNu world
Non è cambiato un pelo.
Ho avuto lo stesso suggerimento.
Così, l'ho ignorato ed ho provato
emerge -DNu world
Anche questo dà gli stessi identici errori della volta scorsa, con il comando suggerito.
bene allora fai:
echo "=x11-misc/xdg-user-dirs-gtk-0.9" >> /etc/portage/package.mask
poi
emerge --sync
emerge --depclean
emerge -DNu world
emerge --depclean
ha dato lo stesso identico risultato di prima.
emerge -DNu world
Mi sembra un po' cambiato:
darkstar / # emerge -DNu world
!!! All ebuilds that could satisfy "x11-misc/xdg-user-dirs-gtk" have been masked.
!!! One of the following masked packages is required to complete your request:
- x11-misc/xdg-user-dirs-gtk-0.9::gentoo (masked by: package.mask)
(dependency required by "x11-misc/xdg-user-dirs-0.14[nls,gtk]" [installed])
(dependency required by "xfce-base/xfce4-session-4.10.0" [ebuild])
(dependency required by "xfce-base/xfce4-meta-4.10" [ebuild])
(dependency required by "@selected" [set])
(dependency required by "@world" [argument])
For more information, see the MASKED PACKAGES section in the emerge
man page or refer to the Gentoo Handbook.
