[Risolto] Linux sul mio PC: Il Ritorno... è Gentoo!
Re: Linux sul mio PC: Il Ritorno... è Gentoo!
Ottimo.....
Messaggio da Zievatron »
conoscenza ha scritto:Ottimo.....
Questa volta emerge -DNu world si è fermato quì:
>>> Emerging (106 of 164) net-nds/openldap-2.4.28-r1
 * openldap-2.4.28.tgz RMD160 SHA1 SHA256 size ;-) ...                   [ ok ]
 * rfc2307bis.schema-20100722 RMD160 SHA1 SHA256 size ;-) ...            [ ok ]
 * ERROR: net-nds/openldap-2.4.28-r1 failed (setup phase):
 *   To build the ldapc++ library you must emerge openldap with sasl support
 * Call stack:
 *                   ebuild.sh, line  85:  Called pkg_setup
 *   openldap-2.4.28-r1.ebuild, line 215:  Called die
 * The specific snippet of code:
 *   		die "To build the ldapc++ library you must emerge openldap with sasl support"
 * If you need support, post the output of 'emerge --info =net-nds/openldap-2.4.28-r1',
 * the complete build log and the output of 'emerge -pqv =net-nds/openldap-2.4.28-r1'.
 * The complete build log is located at '/var/tmp/portage/net-nds/openldap-2.4.28-r1/temp/build.log'.
 * The ebuild environment file is located at '/var/tmp/portage/net-nds/openldap-2.4.28-r1/temp/die.env'.
 * S: '/var/tmp/portage/net-nds/openldap-2.4.28-r1/work/openldap-2.4.28'
>>> Failed to emerge net-nds/openldap-2.4.28-r1, Log file:
 * Messages for package media-libs/freetype-2.4.8:
 * The TrueType bytecode interpreter is no longer patented and thus no
 * longer controlled by the bindist USE flag.  Enable the auto-hinter
 * USE flag if you want the old USE=bindist hinting behavior.
 * Messages for package dev-lang/tcl-8.5.10-r1:
 * PLEASE NOTE: You are compiling tcl-8.5.10 with
 * threading enabled.
 * Threading is not supported by all applications
 * that compile against tcl. You use threading at
 * your own discretion.
 * If you're upgrading from <dev-lang/tcl-8.5, you must recompile the other
 * packages on your system that link with tcl after the upgrade
 * completes.  To perform this action, please run revdep-rebuild
 * in package app-portage/gentoolkit.
 * If you have dev-lang/tk and dev-tcltk/tclx installed you should
 * upgrade them before this recompilation, too,
 * Messages for package app-shells/bash-completion-1.3:
 * Any user can enable the module completions without editing their
 * .bashrc by running:
 *     eselect bashcomp enable <module>
 * The system administrator can also be enable this globally with
 *     eselect bashcomp enable --global <module>
 * Make sure you at least enable the base module! Additional completion
 * modules can be found by running
 *     eselect bashcomp list
 * If you use non-login shells you still need to source
 * /etc/profile.d/bash-completion.sh in your ~/.bashrc.
 * Messages for package app-shells/gentoo-bashcomp-20101217:
 * To enable command-line completion for gentoo-bashcomp, run:
 *   eselect bashcomp enable gentoo
 * to install locally, or
 *   eselect bashcomp enable --global gentoo
 * to install system-wide. (and/or repoman instead of gentoo if you use
 * repoman frequently)
 * Messages for package sys-apps/man-pages-3.35:
 * If you don't have a makewhatis cronjob, then you
 * should update the whatis database yourself:
 *  # makewhatis -u
 * Messages for package x11-libs/libXi-1.4.3-r1:
 * Some special keys and keyboard layouts may stop working.
 * To fix them, recompile xorg-server.
 * Messages for package sys-apps/dbus-1.4.16:
 * To start the D-Bus system-wide messagebus by default
 * you should add it to the default runlevel :
 * `rc-update add dbus default`
 * Some applications require a session bus in addition to the system
 * bus. Please see `man dbus-launch` for more information.
 * You must restart D-Bus `/etc/init.d/dbus restart` to run
 * the new version of the daemon.
 * Don't do this while X is running because it will restart your X as well.
 * Messages for package net-libs/neon-0.29.6:
 * Neon has a policy of breaking API across minor versions, this means
 * that any package that links against Neon may be broken after
 * updating. They will remain broken until they are ported to the
 * new API. You can downgrade Neon to the previous version by doing:
 *   emerge --oneshot '<net-libs/neon-0.29'
 * You may also have to downgrade any package that has not been
 * ported to the new API yet.
 * Messages for package media-libs/fontconfig-2.8.0-r1:
 * Please make fontconfig configuration changes using `eselect fontconfig`
 * Any changes made to /etc/fonts/fonts.conf will be overwritten.
 * If you need to reset your configuration to upstream defaults, delete
 * the directory /etc/fonts/conf.d/ and re-emerge fontconfig.
 * Messages for package media-fonts/dejavu-2.33:
 * The following fontconfig configuration files have been installed:
 *   20-unhint-small-dejavu-sans-mono.conf
 *   20-unhint-small-dejavu-sans.conf
 *   20-unhint-small-dejavu-serif.conf
 *   57-dejavu-sans-mono.conf
 *   57-dejavu-sans.conf
 *   57-dejavu-serif.conf
 * Use `eselect fontconfig` to enable/disable them.
 * Messages for package dev-lang/python-3.2.2:
 * You have just upgraded from an older version of Python.
 * You should run 'python-updater ${options}' to rebuild Python modules.
 * Messages for package sys-devel/gcc-4.5.3-r2:
 * Fallback PaX marking -r
 *      /var/tmp/portage/sys-devel/gcc-4.5.3-r2/image//usr/libexec/gcc/x86_64-pc-linux-gnu/4.5.3/cc1
 *      /var/tmp/portage/sys-devel/gcc-4.5.3-r2/image//usr/libexec/gcc/x86_64-pc-linux-gnu/4.5.3/cc1plus
 * If you have issues with packages unable to locate libstdc++.la,
 * then try running 'fix_libtool_files.sh' on the old gcc versions.
 * You might want to review the GCC upgrade guide when moving between
 * major versions (like 4.2 to 4.3):
 * http://www.gentoo.org/doc/en/gcc-upgrading.xml
 * Messages for package media-libs/mesa-7.11.2:
 * USE="bindist" was not set. Potentially patent encumbered code was
 * enabled.
 * Messages for package net-nds/openldap-2.4.28-r1:
 * Call stack:
 * Regenerating GNU info directory index...
 * Processed 96 info files.
 * IMPORTANT: config file '/etc/locale.gen' needs updating.
 * See the CONFIGURATION FILES section of the emerge
 * man page to learn how to update config files.
 * IMPORTANT: 2 news items need reading for repository 'gentoo'.
 * Use eselect news to read news items.
 * After world updates, it is important to remove obsolete packages with
 * emerge --depclean. Refer to `man emerge` for more information.
Provo a proseguire. ;)
E questa è la conclusione:
darkstar / # emerge --depclean
 * Depclean may break link level dependencies. Thus, it is
 * recommended to use a tool such as `revdep-rebuild` (from
 * app-portage/gentoolkit) in order to detect such breakage.
 * Always study the list of packages to be cleaned for any obvious
 * mistakes. Packages that are part of the world set will always
 * be kept.  They can be manually added to this set with
 * `emerge --noreplace <atom>`.  Packages that are listed in
 * package.provided (see portage(5)) will be removed by
 * depclean, even if they are part of the world set.
 * As a safety measure, depclean will not remove any packages
 * unless *all* required dependencies have been resolved.  As a
 * consequence, it is often necessary to run `emerge --update
 * --newuse --deep @world` prior to depclean.
 * Dependencies could not be completely resolved due to
 * the following required packages not being installed:
 *   >=dev-db/libdbi-drivers-0.8.3 pulled in by:
 *     dev-db/libdbi-0.8.3
 * Have you forgotten to do a complete update prior to depclean? The
 * most comprehensive command for this purpose is as follows:
 *   emerge --update --newuse --deep --with-bdeps=y @world
 * Note that the --with-bdeps=y option is not required in many
 * situations. Refer to the emerge manual page (run `man emerge`)
 * for more information about --with-bdeps.
 * Also, note that it may be necessary to manually uninstall
 * packages that no longer exist in the portage tree, since it may
 * not be possible to satisfy their dependencies.
darkstar / # revdep-rebuild
 * Configuring search environment for revdep-rebuild
 * Checking reverse dependencies
 * Packages containing binaries and libraries broken by a package update
 * will be emerged.
 * Collecting system binaries and libraries
 * Generated new 1_files.rr
 * Collecting complete LD_LIBRARY_PATH
 * Generated new 2_ldpath.rr
 * Checking dynamic linking consistency
[ 100% ]
 * Dynamic linking on your system is consistent... All done.
Attendo nuove istruzioni. ;)
ora dai:
Poi:
etc-update (-5 se richiesto)
emerge --sync
emerge --depclean
revdep-rebuild
emerge xfce4-meta
conoscenza ha scritto:etc-update (-5 se richiesto)
Oh! Questa volta ho visto cos'è questo "se richiesto". :)
ed ora xfce è sceso a 126. :)
Ultima modifica di Zievatron il mercoledì 7 marzo 2012, 12:21, modificato 1 volta in totale.
...ahahah! Non sempre i file di configurazione vengono aggiornati/editati, ma quando lo sono è bene dire al sistema che sono cambiati! ;)
Fammi sapere se la compilazione procede o meno....
procede, procede. ;)
queste si che sono belle notizie! ;)
Ne mancano ancora tanti?
Si è fermato quì:
>>> Emerging (10 of 126) net-nds/openldap-2.4.28-r1
 * Call stack:
 * Messages for package media-fonts/urw-fonts-2.4.9:
 * If you upgraded from urw-fonts-2.1-r2 some fonts will look a bit
 * different. Take a look at bug #208990 if interested.
 * Call stack:
 * GNU info directory index is up-to-date.
Allora vediamo prima le news:
eselect news read new
Poi dai ancora
emerge --sync
emerge --depclean
revdep-rebuild
emerge xfce4-meta
Riporta se ci sono errori.
Dimenticavo: "rc-update add dbus default" ha riportato errori oppure è andato liscio?
