Per lo stage 3 non era indicato nessun percorso:
tar xvjpf stage3-*.tar.bz2
tar xvjf /mnt/gentoo/portage-latest.tar.bz2 -C /mnt/gentoo/usr
root[gentoo]# cat /mnt/gentoo/etc/make.conf
cat: /mnt/gentoo/etc/make.conf: File o directory non esistente
root[gentoo]# cat /mnt/gentoo/etc/make.globals
# Copyright 1999-2011 Gentoo Foundation
# Distributed under the terms of the GNU General Public License v2
# System-wide defaults for the Portage system
# ** DO NOT EDIT THIS FILE **
# **** CHANGES TO make.conf *OVERRIDE* THIS FILE ****
# ** Incremental Variables Accumulate Across Files **
# ** USE, CONFIG_*, and FEATURES are incremental **
# When compiler flags are unset, many packages will substitute their own
# implicit flags. For uniformity, use an empty string as the default.
CFLAGS=""
CXXFLAGS=""
LDFLAGS=""
FFLAGS=""
FCFLAGS=""
# Default rsync mirror
SYNC="rsync://rsync.gentoo.org/gentoo-portage"
# Default distfiles mirrors. This rotation has multiple hosts and is reliable.
# Approved by the mirror-admin team.
GENTOO_MIRRORS="http://distfiles.gentoo.org"
ACCEPT_LICENSE="* -@EULA"
ACCEPT_PROPERTIES="*"
# Repository Paths
PORTDIR=/usr/portage
DISTDIR=${PORTDIR}/distfiles
PKGDIR=${PORTDIR}/packages
RPMDIR=${PORTDIR}/rpm
# Temporary build directory
PORTAGE_TMPDIR=/var/tmp
# Fetching command (3 tries, passive ftp for firewall compatibility)
FETCHCOMMAND="wget -t 3 -T 60 --passive-ftp -O \"\${DISTDIR}/\${FILE}\" \"\${URI}\""
RESUMECOMMAND="wget -c -t 3 -T 60 --passive-ftp -O \"\${DISTDIR}/\${FILE}\" \"\${URI}\""
FETCHCOMMAND_RSYNC="rsync -avP \"\${URI}\" \"\${DISTDIR}/\${FILE}\""
RESUMECOMMAND_RSYNC="rsync -avP \"\${URI}\" \"\${DISTDIR}/\${FILE}\""
FETCHCOMMAND_SSH="bash -c \"x=\\\${2#ssh://} ; host=\\\${x%%/*} ; port=\\\${host##*:} ; host=\\\${host%:*} ; [[ \\\${host} = \\\${port} ]] && port=22 ; exec rsync --rsh=\\\"ssh -p\\\${port}\\\" -avP \\\"\\\${host}:/\\\${x#*/}\\\" \\\"\\\$1\\\"\" rsync \"\${DISTDIR}/\${FILE}\" \"\${URI}\""
RESUMECOMMAND_SSH=${FETCHCOMMAND_SSH}
FETCHCOMMAND_SFTP="bash -c \"x=\\\${2#sftp://} ; host=\\\${x%%/*} ; port=\\\${host##*:} ; host=\\\${host%:*} ; [[ \\\${host} = \\\${port} ]] && port=22 ; exec sftp -P \\\${port} \\\"\\\${host}:/\\\${x#*/}\\\" \\\"\\\$1\\\"\" sftp \"\${DISTDIR}/\${FILE}\" \"\${URI}\""
# Default user options
FEATURES="assume-digests binpkg-logs
config-protect-if-modified distlocks ebuild-locks
fixlafiles news parallel-fetch parse-eapi-ebuild-head protect-owned
sandbox sfperms strict unknown-features-warn unmerge-logs
unmerge-orphans userfetch"
# Ignore file collisions in /lib/modules since files inside this directory
# are never unmerged, and therefore collisions must be ignored in order for
# FEATURES=protect-owned to operate smoothly in all cases.
# Ignore file collisions for unowned *.pyo and *.pyc files, this helps during
# transition from compiling python modules in live file system to compiling
# them in src_install() function.
COLLISION_IGNORE="/lib/modules/* *.py[co]"
UNINSTALL_IGNORE="/lib/modules/*"
# Enable preserve-libs for testing with portage versions that support it.
# This setting is commented out for portage versions that don't support it.
#FEATURES="${FEATURES} preserve-libs"
# Default chunksize for binhost comms
PORTAGE_BINHOST_CHUNKSIZE="3000"
# By default wait 5 secs before cleaning a package
CLEAN_DELAY="5"
# By default wait 10 secs on an important warning
EMERGE_WARNING_DELAY="10"
# Automatically clean installed packages after they are updated.
# This option will be removed and forced to yes.
AUTOCLEAN="yes"
PORTAGE_BZIP2_COMMAND="bzip2"
# Don't compress files with these suffixes.
PORTAGE_COMPRESS_EXCLUDE_SUFFIXES="css gif htm[l]? jp[e]?g js pdf png"
# Number of mirrors to try when a downloaded file has an incorrect checksum.
PORTAGE_FETCH_CHECKSUM_TRY_MIRRORS="5"
# Minimum size of existing file for RESUMECOMMAND to be called.
PORTAGE_FETCH_RESUME_MIN_SIZE="350K"
# Number of times 'emerge --sync' will run before giving up.
PORTAGE_RSYNC_RETRIES="-1"
# Number of seconds rsync will wait before timing out.
#RSYNC_TIMEOUT="180"
PORTAGE_RSYNC_OPTS="--recursive --links --safe-links --perms --times --compress --force --whole-file --delete --stats --human-readable --timeout=180 --exclude=/distfiles --exclude=/local --exclude=/packages"
# The number of days after the last `emerge --sync` that a warning
# message should be produced.
PORTAGE_SYNC_STALE="30"
# Executed before emerge exit if FEATURES=clean-logs is enabled.
PORT_LOGDIR_CLEAN="find \"\${PORT_LOGDIR}\" -type f ! -name \"summary.log*\" -mtime +7 -delete"
# Minimal CONFIG_PROTECT
CONFIG_PROTECT="/etc"
CONFIG_PROTECT_MASK="/etc/env.d"
# Disable auto-use
USE_ORDER="env:pkg:conf:defaults:pkginternal:repo:env.d"
# Mode bits for ${WORKDIR} (see ebuild.5).
PORTAGE_WORKDIR_MODE="0700"
# Some defaults for elog
PORTAGE_ELOG_CLASSES="log warn error"
PORTAGE_ELOG_SYSTEM="save_summary echo"
PORTAGE_ELOG_MAILURI="root"
PORTAGE_ELOG_MAILSUBJECT="[portage] ebuild log for \${PACKAGE} on \${HOST}"
PORTAGE_ELOG_MAILFROM="portage@localhost"
# Signing command used by repoman
PORTAGE_GPG_SIGNING_COMMAND="gpg --sign --digest-algo SHA256 --clearsign --yes --default-key \"\${PORTAGE_GPG_KEY}\" --homedir \"\${PORTAGE_GPG_DIR}\" \"\${FILE}\""
# These settings were set by the catalyst build script that automatically
# built this stage.
# Please consult /usr/share/portage/config/make.conf.example for a more
# detailed example.
CFLAGS="-O2 -pipe"
CXXFLAGS="${CFLAGS}"
# WARNING: Changing your CHOST is not something that should be done lightly.
# Please consult http://www.gentoo.org/doc/en/change-chost.xml before changing.
CHOST="x86_64-pc-linux-gnu"
# These are the USE flags that were used in addition to what is provided by the
# profile used for building.
USE="mmx sse sse2"
CFLAGS="-march=native -O2 -pipe"
INPUT_DEVICES="mouse keyboard evdev"
VIDEO_CARDS="radeon"
MAKEOPTS="-j2"
ACCEPT_LICENSE="@EULA"
EMERGE_DEFAULT_OPTS="--autounmask=n"
No. Non l'ho ancora creato.conoscenza ha scritto:okay.
ma quindi non hai creato ancora l'utente di Gentoo... giusto?
