Cosa significa? .. Significa che vOlvo è in modalità "Gianni Muciaccia: ON"When is the Source 2 engine coming out for CSGO?
"Source 2 is a bunch of system rewrites. For CSGO, we evaluate these new systems on their individual merits. Some CSGO rework is in progress, such as the UI that utilizes parts of Source 2. Other systems might follow. Some Source 2 systems might never be right for CSGO. Relevant anecdote: When we used to be approached about Source 2 at Majors we would ask "what is it that you're hoping Source 2 will do for CSGO" and for a while the response was "I expect hitboxes will be better." Moving everything to Source 2 would not actually solve that problem. We just went ahead and spent time working on better hitboxes."
CS:GO e Source 2, parla GabeN
Tra le domande fatte a Gabe Newel durante l'AMA su Reddit mi ha colpito questa che riguarda CSGO e il motore Source 2
Re: CS:GO e Source 2, parla GabeN
Valve è in modalità Giovanni Mucciaccia da quando estese il Source col supporto HDR...
vero
