ciao a tutti
circa 2 settimane fa giocando a cod2 si spegne lo schermo e quando si riaccende lo ritrovo così
e spengo il pc dal tasto di accensione.
Una volta riavviato controllando nel registro eventi sta scritto "il driver video è stato ripristinato".
Ora da 2 giorni dopo il messaggio del driver video mi fa pure la schermata blu
log del minidump:
VIDEO_TDR_FAILURE (116)Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: fffffa8006ae34e0, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff880066078f0, The pointer into responsible device driver module (e.g. owner tag).
Arg3: 0000000000000000, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000002, Optional internal context dependent data.
Debugging Details:
FAULTING_IP:
atikmpag+78f0
fffff880`066078f0 4883ec28 sub rsp,28h
DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_TDR_FAULT
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x116
PROCESS_NAME: System
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`02193a28 fffff880`06d15cbc : 00000000`00000116 fffffa80`06ae34e0 fffff880`066078f0 00000000`00000000 : nt!KeBugCheckEx
fffff880`02193a30 fffff880`06d159c6 : fffff880`066078f0 fffffa80`06ae34e0 fffffa80`03c40010 fffffa80`05159410 : dxgkrnl!TdrBugcheckOnTimeout+0xec
fffff880`02193a70 fffff880`06dbcf07 : fffffa80`06ae34e0 00000000`00000000 fffffa80`03c40010 fffffa80`05159410 : dxgkrnl!TdrIsRecoveryRequired+0x1a2
fffff880`02193aa0 fffff880`06de6b75 : fffff8a0`ffffffff 00000000`000231b4 00000000`00000000 00000000`00000000 : dxgmms1!VidSchiReportHwHang+0x40b
fffff880`02193b80 fffff880`06db82d5 : fffffa80`05159410 fffffa80`00000002 00000000`000231b4 00000000`00000000 : dxgmms1!VidSchiCheckHwProgress+0x71
fffff880`02193bb0 fffff880`06de4e7a : 00000000`00000000 fffffa80`05df9850 00000000`00000080 fffffa80`05159410 : dxgmms1!VidSchiScheduleCommandToRun+0x1e9
fffff880`02193cc0 fffff800`03330166 : 00000000`fffffc32 fffffa80`036c1b60 fffffa80`03655890 fffffa80`036c1b60 : dxgmms1!VidSchiWorkerThread+0xba
fffff880`02193d00 fffff800`0306b486 : fffff800`03205e80 fffffa80`036c1b60 fffff800`03213c40 6a646e7a`6f635174 : nt!PspSystemThreadStartup+0x5a
fffff880`02193d40 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KxStartSystemThread+0x16
STACK_COMMAND: .bugcheck ; kb
FOLLOWUP_IP:
atikmpag+78f0
SYMBOL_NAME: atikmpag+78f0
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: atikmpag
IMAGE_NAME: atikmpag.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4edd79fe
FAILURE_BUCKET_ID: X64_0x116_IMAGE_atikmpag.sys
Followup: MachineOwner
Oggi ho aggiornato i driver ai 12.4 e con GPUtool ho eseguito "test for stability". appena avviato nella finestra dell'animazione sono apparsi dei pixel gialli e poi di nuovo bsod.
Ha dato questo problema oltre che con cod2 e GPUtool anche con minecraft dopo aver installato un texturepack e mentre guardavo un video su youtube.
La config del pc:
cpu: intel core i5 2500
scheda madre: gigabyte p67a-ud4-b3
scheda video: sapphire 4870 512mb
alimentatore: corsair hx650
